Latest: Beduff1977
Overall: 17134
Online Now [1103]:
Visitors: 1102
Today: 24053
Total: 109878975
Forums › The Car › 206 Talk › newbie Plus help in changing display
niall83
PostPosted: Sun Nov 06, 2011 7:32 pm Up
Hi guys new here and being doing a bit of searching for a while so Its time to ask for some help. What I have is my girlfriends 2006 206 1.4 8v verve which had the single line display with the back light problem. I bought the larger display(I'll supply a pic) and fitted as replacing bulbs didn't solve the problem. Simply plug and play replacment and working fine all but the temperature which was working ok in the single line display. I'm wondering if anyone on here would know if the pin out would need to be changed to make it work.
new display fitted but no temp
and do you like the led side lights i fitted
I have a 2006 modded Vectra it\'s the girlfriend that has the 206 1.6 8v verve also 206 model
PostPosted: Mon Nov 07, 2011 3:27 am Up
Does the passenger mirror have a temp sensor? Iirc a little dimple on the bottom of mirror will tell you.
PostPosted: Mon Nov 07, 2011 4:29 am Up
Either that or it needs activating in the dash
PostPosted: Mon Nov 07, 2011 4:36 am Up
He says the temp display worked fine when it had the single line display so that rules out the temp sensor.
The 2 -- means the display isnt seeing the temp sensor.
Your BSI configuration needs tweaking with Peugeot Planet.
niall83
PostPosted: Mon Nov 07, 2011 7:22 am Up
Thanks lads, is the software easy got and cheap. I not familar with Peugeots, I am with Vauxhalls and have op-com software that I've used to set up trip computer and xenon lights. I got op-com for £2.99 as I already have a OBDII usb connection lead.
