Online Now [386]:
Visitors: 385
Today: 135739
Total: 144955904
Forums › The Car › 206 Problems › draining cooling system
Tam80
PostPosted: Mon Nov 07, 2011 2:09 am Up
tried other day to drain system to fill it up with fresh coolant...started by trying to take off the bottom hose on the rad..took out the clip..and hose is stuck solid..would`not budge..does it come out ?
ended up just taking expansion tank out and draining as much as i could that way..which was bout 2 1/2 litres i reckon..how much does it hold ?
cheers guys Thumb Up
206/GT/GTI
davecuk
PostPosted: Mon Nov 07, 2011 2:38 am Up
hi,depends on the age of the car, it does come off .but as the radiator stub pipe is ridged it takes some persuasion to remove it.try prising the pipe off by wedging a flat blade screwdriver between the pipe end and the radiator body, also make sure the clip is well back from original position to make moving pipe easier
206 1.9 d silver
PostPosted: Mon Nov 07, 2011 3:04 am Up
Warm up the car a bit (not too hot to burn your self) helps to get stubborn pipes of,
PostPosted: Mon Nov 07, 2011 3:46 am Up
even you take the hose off it won't drain the coolant in the engine block
Tam80
PostPosted: Mon Nov 07, 2011 6:29 am Up
whats best way to drain coolant out then ?
206/GT/GTI
PostPosted: Mon Nov 07, 2011 7:17 am Up
Tip the car upside down or run a hosepipe through the reservoir to flush out the system.
Does the radiator not have a drain plug?
panzer360gti
PostPosted: Mon Nov 07, 2011 7:58 am Up
You should get about 7 litres of fluid out, if you only took 2.5 your not doing it right, you need to unscrew the bleed valve behind the engine (from header) radiator tap, and release hoses if you can. Worked for me, but remember to close everything back up after you have refilled and bled.
Peugeot 206 GTI 137 2.0
Ali_H
PostPosted: Mon Nov 07, 2011 8:11 am Up
Rolling On The Floor Laughing
kurtis wrote:
LiamGTi180
PostPosted: Mon Nov 07, 2011 12:25 pm Up
there is a bleed 'tap' on the nearside bottom of the radiator. open up that along with the bleed screws and it will drain from the bottom of the radiator. this is the best way as you are draining from the lowest point in the system therefore removing all of the water. and that hose does come out just needs a lot of persuasion
PostPosted: Mon Nov 07, 2011 1:05 pm Up
www.206info.co.uk/Foru...olant.html
i asked exactly the same questions before
PostPosted: Mon Nov 07, 2011 1:26 pm Up
You won't get all the water out because the water in the block is lower than the exit point at the thermostat housing. You will succeed in removing all the water from the radiator. This is why the system needs to be flushed from the reservoir through to the radiator.
