Online Now [1149]:
Visitors: 1148
Today: 184435
Total: 146329223
Forums › The Car › 206 Problems › noisy bootlid when driving
rick-gti
PostPosted: Tue Nov 08, 2011 4:17 am Up
i had this problem with a 306 i had, but was able to stop it by turning the boot stops out more.
this cant be done on the 206, has anyone else had this problem and sorted it??
starting to do my head in now.
clio 197sport owner
PostPosted: Tue Nov 08, 2011 4:20 am Up
If you mean a rattling sound then yer that's common. Bit of tape around lach or
Readjust the latch a bit (on car body side) five min job.
PostPosted: Tue Nov 08, 2011 4:23 am Up
I did both & it made it much better.
rick-gti
PostPosted: Tue Nov 08, 2011 4:26 am Up
will have a go at that, but did try that on my 306 and it did nothing. only ever had this problem with pugs.
might try to get some larger rubber boot stops.
clio 197sport owner
PostPosted: Tue Nov 08, 2011 4:34 am Up
Adjusting the striker plate should reduce it. Might even need adjusting on the hinges (if that's possible on a 206)
What sort of condition is your boot seal in? Might be worth investing in a new one if it's perished or flattened.
rick-gti
PostPosted: Tue Nov 08, 2011 5:25 am Up
boot seal is fine, am going to try some tape on the latch and move catch slightly.
clio 197sport owner
Lecktorious
PostPosted: Tue Nov 08, 2011 5:34 am Up
Trade Rating: +59
The striker on the latch is worn. Wrap it in tape or replace it.
'98 Nile Blue 306 GTi 6
jimjam19927
PostPosted: Tue Nov 08, 2011 6:05 am Up
I just pulled my latch back and it made it much tighter. No rattle now Smile
Member: 685
I Over Use Smilies Razz
PostPosted: Tue Nov 08, 2011 7:31 am Up
The latch has a plastic sleeve on it that wears. Just replace the whole thing or rotate the sleeve.
Rob2859
PostPosted: Tue Nov 08, 2011 11:34 am Up
Try electrical tape its going to last longer.
