Online Now [540]:
Visitors: 539
Today: 107012
Total: 145412744
Forums › The Car › 206 Problems › wont tick over
wont tick over
dumdum0910
PostPosted: Wed Nov 09, 2011 4:30 pm Up
ill ask about
dumdum0910
PostPosted: Thu Nov 10, 2011 6:59 am Up
found out 1 of my mates has the same coil pack on his motor so tested that and it still ran like crap. so toke apart the throttle body and found it all full of crap. so just waiting for my old man to come back with some carb cleaner .
dumdum0910
PostPosted: Thu Nov 10, 2011 8:10 am Up
cleaned the throttle body , map , icv , tps and still running bad . ive noticed when it does tick over the revs go up and down . could this be the tps ?
mattievrs
PostPosted: Thu Nov 10, 2011 11:20 am Up
guess you'll be best off try a NEW ICV then if it doesnt sort it, id get it to a garage mate.
NO LONGER ACTIVE ON THE FORUM
dumdum0910
PostPosted: Thu Nov 10, 2011 11:43 am Up
after i gave it a run i plugged it in to the obd scanner and it came up idle control system so ordered 1 fingers crossed it fixes it
dumdum0910
PostPosted: Fri Nov 11, 2011 2:18 pm Up
so got a new icv , fitted and made it even worse . revs went straight to 3000 rpm then down to 2000 and started bouncing between 2000 and 2500 :S so toke it off and sent it back as a faulty part, now waiting for another 1 to be delivered
PostPosted: Fri Nov 11, 2011 3:07 pm Up
48-62ohms between pins A and D
48-62ohms between pins B and C
dumdum0910
PostPosted: Fri Nov 11, 2011 4:08 pm Up
which pins what? and is that while engine is running or with just ignition on
PostPosted: Fri Nov 11, 2011 4:18 pm Up
On the ICV when it's removed.
dumdum0910
PostPosted: Fri Nov 11, 2011 4:35 pm Up
right so let me get this right. with the engine off remove the icv with it still connected and check the ohms between the pins ?
PostPosted: Fri Nov 11, 2011 6:16 pm Up
No.
Remove the ICV and check the ohms on the pins on the ICV
dumdum0910
PostPosted: Fri Nov 11, 2011 6:27 pm Up
ok i will do that tomorrow and see what happens
dumdum0910
PostPosted: Sat Nov 12, 2011 8:13 am Up
so checked the old icv pin A and D 47ohm , B and C 47 ohm and with the plunger pushed in A and D 46.8ohm and B and C 46.8 ohms. does this mean the icv is knackered or come the problem be else were?
dumdum0910
PostPosted: Sun Nov 13, 2011 6:28 am Up
could some one advise me on what the temp sensor should be reading? ohms?
dumdum0910
PostPosted: Mon Nov 14, 2011 1:57 pm Up
so replaced the icv again with another new replacment. it was fine for about a second then revs slowly went up to 3krpm Sad i gave it another ecu reset and bsi reset and no change so put in original icv. im now lost on what else it could be. much help appreciated, i have now noticed once its had a run and i leave the car ticking over it will idle normal but once i go to move again and stop at a junction it will run crap again.
Page 2 of 8
