Latest: airmastertapes
Overall: 17133
Online Now [456]:
Visitors: 455
Today: 117565
Total: 106829374
Forums › The Car › 206 Talk › fuel pump relay
fuel pump relay
haggis120
PostPosted: Sun Nov 13, 2011 1:46 pm Up
Does anybody know where the fuel pump relay is on an 2002 1.4 hdi?
or sugestion why the fuel pump wont run, Pumpmis fine and fuse is fine.cheers
haggis120 206 1.4 Hdi, 2002
PostPosted: Sun Nov 13, 2011 1:51 pm Up
It's under the ECU
I have two spare if you need one
haggis120
PostPosted: Sun Nov 13, 2011 1:53 pm Up
Lee is the ECU in the engine bay as I have liffted this and there is nothing there?
PostPosted: Sun Nov 13, 2011 1:55 pm Up
Yes.
It should be, a brown relay, about 15 pins
haggis120
PostPosted: Sun Nov 13, 2011 1:57 pm Up
at the drivers side behind headlight unit? nothing there.
PostPosted: Sun Nov 13, 2011 2:50 pm Up
Under the ECU, if you put your ear near, and get someone to turn the ignition on, you will hear the Relay.
