Latest: Worthy967
Overall: 17143
Online Now [49]:
Visitors: 48
Today: 26342
Total: 114091771
Forums › The Car › 206 Problems › Car not starting without having to press accelerator
Go to page Previous  1, 2, 3
PostPosted: Sun Nov 13, 2011 1:06 pm Up
Take a look here incase it helps: www.206info.co.uk/Foru...rt=34.html
Fitted the spare?
DJRogers88
PostPosted: Sun Nov 13, 2011 1:45 pm Up
Hello - spare was fitted yesterday and has fixed one problem (groggy when setting off - appears old pedal was sticking slightly) but the old problem of cutting out when starting doesn't seem to be fixed as we came back to the car within 30 mins of turning off today and it did the same thing. Your other post is interesting but I wonder if it could be a similar problem as yours is a problem when the engine is cold.. Hmm how can I check servicebox for this problem?
PostPosted: Sun Nov 13, 2011 3:55 pm Up
If it's a fuel-mix issue it could be ECU related.
Note yours is also TU3A setup which means electric throttle body controled by the ECU.
DJRogers88
PostPosted: Mon Nov 14, 2011 7:09 am Up
Hmm interesting - where can I check to see if the car has the known problem with the ECU?
Page 3 of 3
