Online Now [946]:
Visitors: 945
Today: 152980
Total: 148913263
Forums › The Car › 206 Talk › What connector?
What connector?
Forum Index › 206 Talk
Go to page Previous  1, 2
PostPosted: Tue Nov 15, 2011 3:37 am Up
Take a pic of what you have
mtempsch
PostPosted: Tue Nov 15, 2011 11:53 am Up
karimali831 wrote:
I have got the clips now and understand the wiring diagram but don't understand how the wires will fit inside? I was told there is another part that connects to the clip but is not sold as a seperate as it should come from the loom. For my case I just have those 3 wires and clip any suggestions?
From your description I'm not really sure what you've got, but typically for a connector that sits at the end of wires:
The complete connector is actually a shell that houses contact elements.
The elements are typically crimped on to the the end of the wires from the loom and then pushed into the connector(from the 'loom side' i.e. not the side that faces the mating connector)).
A small metal flap flexes enough over a ridge in the housing to let the element slide into the housing but once in the flap prevents it from backing out again. If you for dome reason ever want to disassemble it again, you need to insert a very thin piece of metal from the contact/front/mating side and depress the flap in order to let the element back out.
Sample images
HTH
Silvermetallic 2004 206 RC
PostPosted: Tue Nov 15, 2011 11:54 am Up
He should have the 2 new grey plastic connectors that will plug in to the crystal headlamps & the 6 metal pins if the correct parts where ordered.
I get the feeling the pins havent been ordered.
karimali831
PostPosted: Tue Nov 15, 2011 5:45 pm Up
I visited peugeot dealer and the guy said the part (you referred as 6 metal pins) is not sold as a seperate item and can only be obtained from the loom? Confused Shocked
206 GTI 180
PostPosted: Tue Nov 15, 2011 5:49 pm Up
Lee & also myself have posted the part number up for the pins several times.
Did you ask by part number?
karimali831
PostPosted: Tue Nov 15, 2011 5:55 pm Up
Sorry I had a search and was only able to pick out the Elec clip part number but not the other part, 6 pins?
Why 6 pins when there are 3 wires and in wiring diagram it shows wires connecting directly to Elec clip?
Sorry for these questions.. lol
If someone could show pic of their wiring that would help a lot, it's a bit confusing...
thanks
206 GTI 180
PostPosted: Tue Nov 15, 2011 5:57 pm Up
6 pins
3 for each plug
Each headlight takes one h7 plug.
Each plug has dipped beam, full beam, earth.
PostPosted: Tue Nov 15, 2011 5:59 pm Up
If you have the special insert / removal tool you can reuse the original pins BUT the tool is more expensive then just getting 6 new pins Wink
Page 2 of 2
