Latest: tebas93089
Overall: 17179
Online Now [127]:
Visitors: 126
Today: 33437
Total: 138507030
Forums › The Car › 206 Problems › running hotter than normal
mackem54
PostPosted: Thu Nov 17, 2011 10:39 am Up
hi guys,
went to work this morning noticed she was running hotter than normal so decided would check water level at lunchtime,went out to check and on removal of expansion tank cap noticed the water was rather oily,poured some water in to overflow tank to overfill and get rid of oil on surface of water and there was blobs of black what i think is oil coming to the surface,the history few weeks ago heater wasnt working very good so removed matrix cleaned it tested it all tubes getting hot when i poured boiling water in,so replaced in car, decided to flush coolant system .
after running car with flush in dropped all the water and refilled with water and half antifreeze the book says the coolant takes approx 6 litres of water when i filled it up it took nothing like that,so ran it decided if it had a airlock the water level would eventually drop and i could top it up,
when driving car home from work no loss of power temp not as high as this morning, took off rocker box cover and there is no water there checked dipstick the oil is as clear as a bell no emulsifying,so anyone out there have any ideas, thanks
keep on to the end of the road
dumdum0910
PostPosted: Thu Nov 17, 2011 11:26 am Up
sounds like could be the headgasket. when mine went there was only oil in the coolant tank with no mayo on the oil filler cap or on the dipstick .
Rob2859
PostPosted: Thu Nov 17, 2011 1:52 pm Up
Sounds like the gasket to me.
Rob2859
PostPosted: Thu Nov 17, 2011 1:53 pm Up
