Latest: tbafonso
Overall: 17130
Online Now [502]:
Visitors: 501
Today: 36535
Total: 103153301
Forums › The Car › 206 Problems › cylinder head replacing
steveaddy
PostPosted: Fri Nov 18, 2011 3:14 pm Up
Hi all, I wondered if anybody could give me and tips or advice. I am slowly trying to repair my wifes 1.1.pug 206 04 plate.
The cambelt slipped a while ago and damaged the head. I bought a replacement head from ebay which had been reconditioned. I stripped the damaged head off and the valves had been damaged and slighlty marked the pistons. The replacement head I got was from a 2002 Peugeot 206 1.1 and was told by the man I bought it off who said was a mechanic it would fit.
Ive since put the new head on and all mates up with the block fine but has a slight defference to the old head as the inlet manifold is different, I have got one that will fit from the scrapyard it looks different to the one I had on it is a more square style and the connections are in different places I think I have figured what goes where apart from one connecter that has a different end so I think I am just going to swap the connection over so it fits the plug.
The 2nd problem I have is the cambelt sprocket on the new head is bigger than my old one. Does this make a difference? It has a larger bolt holding it on so i am not sure if i can swap it for my the one on my old head? As when i went to pull the cambelt over the sprocket it will not go. I know pug do 2 belts one slightly larger with a few more teeth so could i just get the bigger belt? Any help would be fantastic and i hope one day to get this car started!
Thanks, Steve
pug 206
PostPosted: Fri Nov 18, 2011 4:06 pm Up
I gave up reading it halfway because of a lack of paragraphs.
PostPosted: Fri Nov 18, 2011 8:29 pm Up
OP edited for spelling, punctuation and grammar to make it actually make f*****g sense because I am feeling nice. No need to thank me, I do this for free because I enjoy it. Rolling Eyes
PostPosted: Sat Nov 19, 2011 4:16 am Up
Laughing
Nice.
gazza82
PostPosted: Sat Nov 19, 2011 10:17 am Up
Doesn't sound like the new head he bought is the right one!
steveaddy
PostPosted: Sat Nov 19, 2011 3:36 pm Up
sorry about that.I have to use my mobile phone for the internet at the moment.
pug 206
