Online Now [503]:
Visitors: 502
Today: 91548
Total: 145397299
Forums › The Car › 206 Problems › OBD2 Port
OBD2 Port
allstaramber
PostPosted: Sun Nov 20, 2011 12:26 pm Up
Hi guys,
I have a Peugeot 206 sport 1.1, its a 55 plate.
Basically the engine management light has come on and now won't go off (its orange, not red). to get it off before, all i had to do was push the plugs back together. That is no longer working.
there's a diagnostic reader on ebay that im looking to buy but im not sure where the port is that i have to connect it to. Any ideas please?
Thanks guys and gals Very Happy
heeeeeeelp!!!
PostPosted: Sun Nov 20, 2011 12:29 pm Up
Flap to the right of the drivers knee, turn the plastic screw with a coin & lift the flap up & of.
gazza82
PostPosted: Sun Nov 20, 2011 12:31 pm Up
In the fuse box behind the lower cover under the dash by your knees.
Only don't get an ODB2 compatible .. you need an EODB one. It should be compatible as all european cars had to be standardised after Sept 2001 (petrol) and Sept 2004 (diesel). But there are some differences with newer systems and PSAs multiplex might be the same. So make sure it's on a refund basis.
