Latest: jackrox1992
Overall: 17186
Online Now [1026]:
Visitors: 1025
Today: 140867
Total: 148667227
Forums › The Car › 206 Problems › ABS or Not ABS that is the Question !!
Linkpad
PostPosted: Mon Nov 21, 2011 9:32 am Up
I have a 206 GTI 138 W Reg 2000 which needs a new rear axle and i cannot for the life of me determine if it has ABS or not !!
I see a shiney metal thing below bonnet infront of headlights that looks like an ABS module, but i see no ABS light come on when ignition is on and i see no ABS wire connecting to the brakes themselves ? How can i tell ? Rolling Eyes
Boo
PostPosted: Mon Nov 21, 2011 9:48 am Up
It has ABS.
PostPosted: Mon Nov 21, 2011 11:36 am Up
Most likely the bulb in the cluster has blown or more likely been removed to hide a fault Wink
Check / replace the instrument cluster bulb for the ABS.
Coolspot
PostPosted: Mon Nov 21, 2011 1:21 pm Up
Also check your rear axle for a black rubber like cable about 30cm long coming from the back of each disc to a blue plug at each side. Then you will know if the axle is an ABS one.
I chopped mine off as my car doesn't have the safety feature to plug into.
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
Linkpad
PostPosted: Tue Nov 22, 2011 3:19 am Up
Yeah, Thanks for the help i see 2 black cables on the bake caliper but they look Hydraulic but i haven't looked closely. As far as bulbs are concerned all my lights work properly so why would this effect the ABS but i do agree i do need a new Instrument cluster (problems).
If i get a Rear Axle with ABS does that mean i could just chop the wires off and still use it ?
Cool
Boo
PostPosted: Tue Nov 22, 2011 11:07 am Up
GTI needs the ABS to work else it will fail the mot test so no you cant chop the abs sensors off Wink
ABS warning light on the instrument cluster should come on at the pre start warning bulb check & go off after a few seconds after testing the system & finding eveything is ok.
Pop the cluster out & check / replace the bulb for the abs lamp.
