Latest: KevinRC
Overall: 17137
Online Now [721]:
Visitors: 720
Today: 41291
Total: 111182742
Forums › The Car › 206 Problems › running water sound from passenger side
QuArTz
PostPosted: Fri Nov 25, 2011 6:41 am Up
Trade Rating: +16
Over the last month or so I have been hearing an 'running water' sound from the passengers side.
It mainly happens when the car is idle and I rev the engine.
It sound like bubbling, running water and its always from the passengers side.
Any ideas would be greatly appriciated.
Big_Rich180
PostPosted: Fri Nov 25, 2011 6:53 am Up
Im not sure what the noise is but im sure this has been covered before so it may be worth a search if no one has an answer soon.
Matt
PostPosted: Fri Nov 25, 2011 7:45 am Up
Trade Rating: +32
Either brake servo or Headgasket.
QuArTz
PostPosted: Fri Nov 25, 2011 8:13 am Up
Trade Rating: +16
Ive just had a look at the expantion bottle and it was bone dry, now ive topped it up to the 'MAX' level and took the car for a spin, the fan came on, on two occations and the water level hasnt dropped, the temp guage hasnt moved much above 90'c
The sloshing water sound was still there when I accelarated while the stationary, although as before the sound went away once the car had warmed up.
Ive had a look at the previous posts on this topic but havent seen any solutions to this problem.
Ash
PostPosted: Fri Nov 25, 2011 8:30 am Up
Mine does this from time to time. Car runs perfectly with no problems at all.
So be interesting to find out what happens. Lee mentioned air in the matrix once but I've had no temp issues. It stays at 93 happily and raises to 95 ish when trashing but never more.
panzer360gti
PostPosted: Fri Nov 25, 2011 10:27 am Up
I cant believe people still ask this, it is covered so many times!
Peugeot 206 GTI 137 2.0
QuArTz
PostPosted: Fri Nov 25, 2011 2:47 pm Up
Trade Rating: +16
and I still cant believe that people like you still feel it's ok to leave comments that are no use, other than to notch up their post count..
PostPosted: Fri Nov 25, 2011 2:51 pm Up
www.206info.co.uk/Foru...36283.html
panzer360gti
PostPosted: Sat Nov 26, 2011 3:16 am Up
People like me? Do I have a post count? Do I care?
The question is asked over and over again, if nobody has answered it or solved it then what is gonna change from yesterday to today?
Did you not just "notch up your post count" yourself, by posting a load of abusive kid crap?
jonnycool
PostPosted: Wed Nov 30, 2011 6:32 pm Up
NorthantsBen wrote:
http://www.206info.co.uk/Forums/viewtopic/t=36283.html
In the OP's defence, this link doesn't provide a conclusive solution to the problem Rolling Eyes
2000 1.6 Roland Garros
PostPosted: Wed Nov 30, 2011 6:38 pm Up
I didn't say it did, it's purely for refrence/ ideas.
danlouiee
PostPosted: Thu Dec 01, 2011 11:03 am Up
I had it, piston liner had dropped, needed a rebuild possible head gasket fault, it's the noise of you pumping water around your engine. The heater matrix would be only if you had water in the footwell.
greenpug2222
PostPosted: Sun Dec 04, 2011 8:56 pm Up
HI i also have this issue, however it goes away when my girlfriend is in the passenger seat with me...... could the balance of the car effect it somehow???
why wont you work??????????????????? ARGH F**k it!!!!!
rick-gti
PostPosted: Mon Dec 05, 2011 4:01 am Up
check the oil, if there's a white mayo on the distick/oilcap then headgasket might have gone.
could also take to a garage and they can check the expansion bottle for exhaust gasses which will tell you if the headgasket has gone. might also be worth bleeding the coolant system.
have had this with both 306 gti6's i have had and never had a problem. i just drained and re-filled the coolant.
clio 197sport owner
