Online Now [197]:
Visitors: 196
Today: 5541
Total: 138684875
Forums › The Car › 206 Talk › 206 gti engine mods
206 gti engine mods
rick-gti
PostPosted: Fri Nov 25, 2011 11:33 am Up
My gti 140 is sounding a little tappety. So I am thinking of takin the engine out in the new year and replacing the cams/followers ect. Are there any mods I could do with the engine out? Wouldnt mind uprated cams. Obviously im goin to have to buy gasket, cambelt kit and maybe clutch so my budget isnt goin to be to high (to spend on uprated parts) the car is standard at the moment.
clio 197sport owner
PostPosted: Fri Nov 25, 2011 11:49 am Up
need a budget
luke030588
PostPosted: Fri Nov 25, 2011 1:08 pm Up
eBay electric supercharger......
04 plate silver, gloss black nimrods, 180 brakes, more to come.....
Mattie-RS
PostPosted: Fri Nov 25, 2011 1:16 pm Up
Good one Rolling Eyes
It depends on how mucj you can afford to spend tbh
rick-gti
PostPosted: Fri Nov 25, 2011 2:26 pm Up
Wouldnt waste my money on them s**t electric superchargers? Think im just goin to strip the head and re-new cams if need be and re-seat valves. Never taken an engine out of a 206 before (have done on a 306 gti 6) any easy way of doin it? When I done the 306 I took front end off and lifted it out with gearbox.
clio 197sport owner
macj
PostPosted: Fri Nov 25, 2011 2:35 pm Up
I would suggest you leave the cams alone. If you want good power you need to think inlet and compression ratio Wink
rick-gti
PostPosted: Fri Nov 25, 2011 2:39 pm Up
Im sticking with the standard cams, just goin to strip the head and rebuild it to cure the tap I have.
clio 197sport owner
macj
PostPosted: Fri Nov 25, 2011 2:43 pm Up
You can always send it to Charlie at CTM Performance Engineering. Tell him I sent you and he will work his magic on it for a fee
rick-gti
PostPosted: Fri Nov 25, 2011 3:44 pm Up
After seeing prices for cam kits im goin to keep the engine standard. To remove the head is it easier to remove the engine or take head off with it left in? Want to get it running sound for when I sell it. With this done should add abit more value to it.
clio 197sport owner
macj
PostPosted: Fri Nov 25, 2011 3:56 pm Up
leave the lump in and remove head
