Posted: Tue Nov 29, 2011 9:15 am |
my rear spoiler has dropped off! tried using double sided pads from halfords but they lasted about 6month...underneath the spoiler are two screw holes, but where the spoiler sits on the car there isnt any fitting holes for anything to screw into! its an original factory spoiler..
do pug sell factory industrial sticky pads??
Posted: Tue Nov 29, 2011 9:22 am |
Posted: Tue Nov 29, 2011 9:41 am |
If you want to screw it on you'll need to drill the holes for it
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Tue Nov 29, 2011 9:42 am |
Just use tigerseal, more than strong enough
Posted: Tue Nov 29, 2011 10:30 am |
They must of been mighty strong sticky pads to 6 months tho....
But as said use tiger seal
Posted: Tue Nov 29, 2011 10:36 am |
| oldbanger2 wrote: |
do pug sell factory industrial sticky pads??  |
Nope, Peugeot drill holes & fit the spoiler correctly instead of bodging it
Posted: Tue Nov 29, 2011 2:13 pm |
one side was fitted factory firm, the other side had come loose so i used after market suff....begining to think someone was trying to nick it. but it was just on the floor this morning!
Posted: Tue Nov 29, 2011 3:03 pm |
Good job is was on the floor this morning, and not when your doing a ton down the Mway
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Tue Nov 29, 2011 3:13 pm |
there are two pre- drilled holes in the spoiler but not on the boot lid! and even if i drilled two holes i cant see how you can possibly screw the bolts to the boot lid as there isnt any access as the spoiler would be flush...
Posted: Tue Nov 29, 2011 3:16 pm |
| oldbanger2 wrote: |
| there are two pre- drilled holes in the spoiler but not on the boot lid! and even if i drilled two holes i cant see how you can possibly screw the bolts to the boot lid as there isnt any access as the spoiler would be flush... |
You need to open the tailgate to fit the screws that secure the spoiler
Posted: Tue Nov 29, 2011 3:29 pm |
only holes on mine are where the rear washer/ribbed pipe goes thru.. is that it?
Posted: Tue Nov 29, 2011 3:31 pm |
| oldbanger2 wrote: |
| only holes on mine are where the rear washer/ribbed pipe goes thru.. is that it? |
YOU have to drill the holes for the spoiler yourself.
When you buy a genuine Peugeot spoiler it comes with idiot proof instructions, drilling templates, fixing hardware & rust preventor for the holes you need to drill.
Posted: Tue Nov 29, 2011 3:54 pm |
i have no template & spoiler is original..just seen a how to on hear but on his car he had a gromet, poped that off and drilled..
Posted: Tue Nov 29, 2011 3:59 pm |
Just tiger seal it on to save yourself all the hard work off drill it, or ask a body shop to drill them for you and then you can't f**k it up yourself! That what i need
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Tue Nov 29, 2011 4:17 pm |
i,ll have a go tomoro, its best to bolt it on then it cant be stolen or drop off!!
