Posted: Wed Nov 30, 2011 3:30 pm |
Passenger side engine support is practically a block of gum with a bolt that is screwed to a nut welded to chassis.
Now, my problem is that nut is no more welded! I replaced it with a "blocked" one, but engine movement makes it always loosen...
Anyone had this problem and managed to solve it?
Thank a lot!
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Posted: Wed Nov 30, 2011 3:36 pm |
you could always get a garage to tack the nut back on with a welder
Posted: Wed Nov 30, 2011 3:38 pm |
Have you tried using an anti shake washer under the nut?
Posted: Wed Nov 30, 2011 4:08 pm |
liquid thread lock.
anti shake washer won't handle that kind of force
Posted: Wed Nov 30, 2011 4:44 pm |
weld a plate over the captive nut with a hole drilled in it.... This stops it turning.... I have just done this mod
Posted: Wed Nov 30, 2011 7:08 pm |
Seabook wrote: |
liquid thread lock.
anti shake washer won't handle that kind of force |
Thread lock is useless, better of with a Nordlock washer, they never come loose
Posted: Thu Dec 01, 2011 3:34 pm |
Thread lock and washer are useless, I already tried... I'll try macj suggestion, thank you (as usual...)
I'll post results...
Posted: Fri Dec 02, 2011 3:24 pm |
@macj, do you remember the dimension of the plate you used? Thanks!
Posted: Fri Dec 02, 2011 3:52 pm |
40mm square with 14mm hole in the centre
Posted: Fri Dec 02, 2011 3:54 pm |
macj do you have any issues with nuts / bolts coming loose even with threadlock applied?
Posted: Sat Dec 03, 2011 4:00 am |
MrBSI wrote: |
macj do you have any issues with nuts / bolts coming loose even with threadlock applied? |
Yes mate... The two ARB bolts on the rear radius arms, the rear damper bolts. We spanner check before each event now. The engine mount ripped the captive out of the chassis but with the 16swg plate over it there seems to be no further issue
Posted: Sat Dec 03, 2011 4:05 am |
macj wrote: |
MrBSI wrote: |
Yes mate... The two ARB bolts on the rear radius arms, the rear damper bolts. We spanner check before each event now. The engine mount ripped the captive out of the chassis but with the 16swg plate over it there seems to be no further issue |
Might be worth looking in to some Nordlock washers, there fitted to a lot of forklifts.
www.nord-lock.com/
Once torqued up these never come undone by themselves.
www.nord-lock.com/defa...rl=2.16.37
Posted: Sat Dec 03, 2011 4:21 am |
good call.... can I have some 8mm and some 10mm please
No. 1226 and 1236
Posted: Sat Dec 03, 2011 4:56 am |
MrBSI wrote: |
macj wrote: |
MrBSI wrote: |
www.nord-lock.com/
www.nord-lock.com/defa...rl=2.16.37 |
would it rip off the contact surface?
Posted: Sat Dec 03, 2011 5:16 am |
macj wrote: |
No. 1226 and 1236 |
Ill see whats in my secret stock of parts at work
