Latest: Puggingalong
Overall: 17129
Online Now [207]:
Visitors: 206
Today: 61395
Total: 101756311
Forums › The Car › 206 Problems › 206 Rear Axle Replacement
Linkpad
PostPosted: Fri Dec 02, 2011 12:31 pm Up
Bugger so the compensator is built into the axle itself not the brake caliper ?
Boo
martinius88
PostPosted: Fri Dec 02, 2011 12:32 pm Up
Why not heed the advice of people that know what they're talking about?? Whats the point of not having the abs just because its a 'newer' axel... In reality anything could go wrong straight away regardless of the age. Also wouldn't it be cheaper to get a slightly older one? And the abs is linked to the brakes not axel.
My opinion anyway, as i dont think itll improve the performance in anyway. Well upto you mate.
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
Linkpad
PostPosted: Fri Dec 02, 2011 12:36 pm Up
Well i already ordered the axle and the mechanic said it would be fine so i thought i would ask here check and you said it wouldn't luckily ebay do refunds. Im just worried if i get another axle the same age ill just get the same friggin problem !!
"Dont let the sound of your own wheels drive you crazy !!"
Boo
PostPosted: Fri Dec 02, 2011 1:01 pm Up
Edward wrote:
My Dec 2000 build GTi doesn't have a compensator.
Yours has working ABS as well Laughing
martinius88
PostPosted: Fri Dec 02, 2011 1:36 pm Up
Ahhh i see, fair enough, well whatever you decide todo hopefully it all works out and grt it sorted Smile
PostPosted: Fri Dec 02, 2011 1:52 pm Up
None of the ones I had had a compensator on the axle, always a first though Laughing
Linkpad
PostPosted: Fri Dec 02, 2011 3:53 pm Up
how can u tell ? I thought it was 2 good to see a 2004 206 axle on Ebay. Who needs MOTs anyway !!
Boo
PostPosted: Fri Dec 02, 2011 3:56 pm Up
my git axle got no compensator.
there is always loads of disc axle on ebay.
you could always just swap the axle tube only, that would solve everything
Linkpad
PostPosted: Fri Dec 02, 2011 4:32 pm Up
is it a git or a gti ? i think mines a git
Boo
PostPosted: Fri Dec 02, 2011 4:43 pm Up
typo, is gti Laughing
Rob2859
PostPosted: Fri Dec 02, 2011 6:59 pm Up
Age has nothing to do with it anyway I would be more interested in the mileage it has done.
Lecktorious
PostPosted: Sat Dec 03, 2011 3:07 am Up
Trade Rating: +59
Incorrect.
I beam on a car that has sat up for years will be worse than a beam from a car that has been used.
'98 Nile Blue 306 GTi 6
Linkpad
PostPosted: Sat Dec 03, 2011 8:21 am Up
Coudnt i just fit the rear brakes off my old axle onto the new axle with the ABS being correct ?
Boo
PostPosted: Sat Dec 03, 2011 8:29 am Up
I've had three axles, two had compensators and one didn't. All the same age
Linkpad
PostPosted: Sat Dec 03, 2011 8:37 am Up
Ill wait until the 2004 year axle comes for my 2000 GTI and get the mechanic to look on Monday I can see the ABS pump with the six pipes coming off it but not sure where u can see the compensators ? Its just a hydraulic driven pump as far as im concerned but it definatley works as the lights goes away when i start ignition ...
Boo
Page 2 of 3
