Latest: Worthy967
Overall: 17143
Online Now [523]:
Visitors: 522
Today: 81387
Total: 115271741
Forums › The Car › 206 Problems › Engine mount BIG problem
gpvecchi
PostPosted: Wed Nov 30, 2011 3:30 pm Up
Passenger side engine support is practically a block of gum with a bolt that is screwed to a nut welded to chassis.
Now, my problem is that nut is no more welded! I replaced it with a "blocked" one, but engine movement makes it always loosen...
Anyone had this problem and managed to solve it?
Thank a lot!
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
ExoVyper
PostPosted: Wed Nov 30, 2011 3:36 pm Up
you could always get a garage to tack the nut back on with a welder
PostPosted: Wed Nov 30, 2011 3:38 pm Up
Have you tried using an anti shake washer under the nut?
PostPosted: Wed Nov 30, 2011 4:08 pm Up
liquid thread lock.
anti shake washer won't handle that kind of force
macj
PostPosted: Wed Nov 30, 2011 4:44 pm Up
weld a plate over the captive nut with a hole drilled in it.... This stops it turning.... I have just done this mod
PostPosted: Wed Nov 30, 2011 7:08 pm Up
Seabook wrote:
liquid thread lock.
Thread lock is useless, better of with a Nordlock washer, they never come loose Wink
gpvecchi
PostPosted: Thu Dec 01, 2011 3:34 pm Up
Thread lock and washer are useless, I already tried... I'll try macj suggestion, thank you (as usual...)
I'll post results...
gpvecchi
PostPosted: Fri Dec 02, 2011 3:24 pm Up
@macj, do you remember the dimension of the plate you used? Thanks!
macj
PostPosted: Fri Dec 02, 2011 3:52 pm Up
40mm square with 14mm hole in the centre
PostPosted: Fri Dec 02, 2011 3:54 pm Up
macj do you have any issues with nuts / bolts coming loose even with threadlock applied?
macj
PostPosted: Sat Dec 03, 2011 4:00 am Up
Yes mate... The two ARB bolts on the rear radius arms, the rear damper bolts. We spanner check before each event now. The engine mount ripped the captive out of the chassis but with the 16swg plate over it there seems to be no further issue
PostPosted: Sat Dec 03, 2011 4:05 am Up
Might be worth looking in to some Nordlock washers, there fitted to a lot of forklifts.
www.nord-lock.com/
Once torqued up these never come undone by themselves.
www.nord-lock.com/defa...rl=2.16.37
macj
PostPosted: Sat Dec 03, 2011 4:21 am Up
good call.... can I have some 8mm and some 10mm please Wink
No. 1226 and 1236
PostPosted: Sat Dec 03, 2011 4:56 am Up
www.nord-lock.com/
would it rip off the contact surface?
PostPosted: Sat Dec 03, 2011 5:16 am Up
No. 1226 and 1236
Ill see whats in my secret stock of parts at work Laughing
