Posted: Fri Dec 02, 2011 12:31 pm |
Bugger so the compensator is built into the axle itself not the brake caliper ?
Posted: Fri Dec 02, 2011 12:32 pm |
Why not heed the advice of people that know what they're talking about?? Whats the point of not having the abs just because its a 'newer' axel... In reality anything could go wrong straight away regardless of the age. Also wouldn't it be cheaper to get a slightly older one? And the abs is linked to the brakes not axel.
My opinion anyway, as i dont think itll improve the performance in anyway. Well upto you mate.
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454 | |
Posted: Fri Dec 02, 2011 12:36 pm |
Well i already ordered the axle and the mechanic said it would be fine so i thought i would ask here check and you said it wouldn't luckily ebay do refunds. Im just worried if i get another axle the same age ill just get the same friggin problem !!
"Dont let the sound of your own wheels drive you crazy !!"
Posted: Fri Dec 02, 2011 1:01 pm |
Edward wrote: |
My Dec 2000 build GTi doesn't have a compensator. |
Yours has working ABS as well
Posted: Fri Dec 02, 2011 1:36 pm |
Linkpad wrote: |
"Dont let the sound of your own wheels drive you crazy !!" |
Ahhh i see, fair enough, well whatever you decide todo hopefully it all works out and grt it sorted
Posted: Fri Dec 02, 2011 1:52 pm |
None of the ones I had had a compensator on the axle, always a first though
Posted: Fri Dec 02, 2011 3:53 pm |
how can u tell ? I thought it was 2 good to see a 2004 206 axle on Ebay. Who needs MOTs anyway !!
Posted: Fri Dec 02, 2011 3:56 pm |
my git axle got no compensator.
there is always loads of disc axle on ebay.
you could always just swap the axle tube only, that would solve everything
Posted: Fri Dec 02, 2011 4:32 pm |
is it a git or a gti ? i think mines a git
Posted: Fri Dec 02, 2011 4:43 pm |
typo, is gti
Posted: Fri Dec 02, 2011 6:59 pm |
Age has nothing to do with it anyway I would be more interested in the mileage it has done.
Posted: Sat Dec 03, 2011 3:07 am |
Trade Rating: +59
Rob2859 wrote: |
Age has nothing to do with it anyway I would be more interested in the mileage it has done. |
Incorrect.
I beam on a car that has sat up for years will be worse than a beam from a car that has been used.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sat Dec 03, 2011 8:21 am |
Coudnt i just fit the rear brakes off my old axle onto the new axle with the ABS being correct ?
Posted: Sat Dec 03, 2011 8:29 am |
I've had three axles, two had compensators and one didn't. All the same age
Posted: Sat Dec 03, 2011 8:37 am |
Ill wait until the 2004 year axle comes for my 2000 GTI and get the mechanic to look on Monday I can see the ABS pump with the six pipes coming off it but not sure where u can see the compensators ? Its just a hydraulic driven pump as far as im concerned but it definatley works as the lights goes away when i start ignition ...
