Latest: Kifi69
Overall: 17183
Online Now [634]:
Visitors: 634
Today: 149926
Total: 143989900
Forums › The Car › 206 Talk › Laser Tools 3396 hub tool
PostPosted: Mon Dec 05, 2011 4:21 pm Up
Am I right in thinking these are used to lever the hub apart slightly to make pulling the damper out of the hub easier?
macj
PostPosted: Mon Dec 05, 2011 4:32 pm Up
makes perfect sense
PostPosted: Mon Dec 05, 2011 4:56 pm Up
Its not hard anyway. Never needed these tools when ive removed my dampers. Just undoing the hub nut loosens it enough.
PostPosted: Tue Dec 06, 2011 3:03 am Up
But they are a tight fit so there's often the need for a hammer. If there's a more precise way of doing it I'd rather buy the tools.
PostPosted: Tue Dec 06, 2011 3:25 am Up
How do they work?
PostPosted: Tue Dec 06, 2011 7:04 am Up
NorthantsBen wrote:
How do they work?
Looks like you stick the end of the tool in the slot & then use a long breaker bar to twist it.
PostPosted: Tue Dec 06, 2011 12:13 pm Up
MrBSI wrote:
NorthantsBen wrote:
How do they work?
was thinking that but wasnt sure if i would be right Laughing thought there might have been a different way Laughing
there quite good idea tbh, tho i find a bolster tapped into the back a tiny bit (so not to damage anything) works fine for me. if there not expensive i would still have a set for my tool box tho lol Very Happy
PostPosted: Thu Dec 29, 2011 12:21 pm Up
These tools are a waste of time for the 206. The gap in the hub is miles too big for the socket to fit.
It does describe the sockets and a hub nut tool but can't see how they would help.
EdCherry
PostPosted: Thu Dec 29, 2011 7:35 pm Up
I took a light skim off the hub some with coarse emery paper, takes a while but did a nice job. Can remove both front dampers from on the floor to on the bench in less than 10 minutes. With a light grease they just slide straight out.
Alternatively I have used a small chisel hammered in the tab to open the aperture up enough to slide the damper out.
