Latest: jackrox1992
Overall: 17186
Online Now [413]:
Visitors: 412
Today: 17875
Total: 148558079
Forums › The Car › 206 Problems › Occasional wobble from offside rear suspension
trackgti
PostPosted: Tue Dec 06, 2011 1:59 pm Up
On and off there's an un-nerving wobble coming from the offside rear it feels like. I'm going to be jacking up the car tomorrow and checking it out, but really would like some advise of what to check out! Very Happy and what's the most likely cause?
The wobble is not consistent in its speed or after going bumps etc, it just occasionally turns up, and is quite un-nerving when the car starts to vibrate and seems to come from that corner.
I've noticed that side looking at the car from the back seems to have slightly more negative camber than the other side if that helps?
What do you peeps recon and where can I get the parts?
Thank you Very Happy
Track toy 206, is this really a good idea? hmmm.
shell-vt
PostPosted: Tue Dec 06, 2011 2:01 pm Up
Trade Rating: +46
well just of what yous saying sounds like rear beam failure?????
york 16,3
PostPosted: Tue Dec 06, 2011 2:02 pm Up
need new trailing arm bearing
trackgti
PostPosted: Tue Dec 06, 2011 2:16 pm Up
Would I be after this then? ... www.ebay.co.uk/itm/REA...4cf82fc21b
Would a general motor factors stock this kind of stuff? and is it possible to fit without the use of a press?
Thanks for the advise Very Happy
