Posted: Tue Dec 06, 2011 4:42 pm |
can you buy a replacement rubber ball-joint gaiter for lower susp. arm? It says in the the haynes that it is available seperately; but where from?
cheers!
| Peugeot 206 HDi (1.4cc) 'eco' - 2005 | |
Posted: Tue Dec 06, 2011 4:44 pm |
never seen one sold separately
Posted: Tue Dec 06, 2011 4:46 pm |
Not seen one sold for years, most likely can still get them if you find a motor factor with old stock on the shelf.
Posted: Tue Dec 06, 2011 4:56 pm |
Seabook wrote: |
never seen one sold separately |
MrBSI wrote: |
Not seen one sold for years, most likely can still get them if you find a motor factor with old stock on the shelf. |
Oh sh*t - just spent £26 quid replacing a bush on the old arm, now the gaiter has split too! ~ Not prepared to pay out for a new arm on ebay or at dealer on top of the £26 I just forked out. Will a gaiter from a track rod end do instead I wonder?
cheers!
Posted: Wed Dec 07, 2011 1:38 am |
Topgear in doncaster split mine when they lowered it, they got hold of some easily enough
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Wed Dec 07, 2011 2:02 am |
I'm sure I've seen them on Servicebox.
Posted: Wed Dec 07, 2011 6:14 am |
Edward wrote: |
I'm sure I've seen them on Servicebox. |
WET ON SERVICE box last night and there were no parts diagrams for suspension? (everything else - yes!)
cheers!
Posted: Wed Dec 07, 2011 6:16 am |
D4NTP wrote: |
Topgear in doncaster split mine when they lowered it, they got hold of some easily enough |
I'll try my local factor then, and JCT...
CHEERS!
Posted: Wed Dec 07, 2011 7:12 am |
Servicebox definately has suspension diagrams.
Posted: Wed Dec 07, 2011 9:52 am |
If the ball joint cover has been split for any length of time, then it's likely that grit has got in and the grease leaked out, which is now causing wear on the joint itself. It's sometimes a waste of money to replace the cover as you'll need a new arm soon enough.
Posted: Wed Dec 07, 2011 12:56 pm |
Edward wrote: |
Servicebox definately has suspension diagrams. |
not coming up on my browser for 206 HDi 1.4. I called my local main dealer who said that the gaiter is not available separately and several other local factors confirmed this too.
Posted: Wed Dec 07, 2011 12:58 pm |
gazza82 wrote: |
If the ball joint cover has been split for any length of time, then it's likely that grit has got in and the grease leaked out, which is now causing wear on the joint itself. It's sometimes a waste of money to replace the cover as you'll need a new arm soon enough. |
many thanx!
Posted: Mon Jan 23, 2012 11:43 am |
EVENTUALLY MANAGED to see the service box diagram and it DOES list a ball joint gaiter [EDWARD], 2 collars, and a protector.
...this time main dealer said: "each of those are only available in packs of 20". They didn't remember telling me that you couldn't buy them separately in the first place! i.e. complete arm only!
...managed to get hold of ONE from this guy: boot/gaiter.
...and got the collars and protector from: protector/collars
