Latest: tebas93089
Overall: 17179
Online Now [138]:
Visitors: 138
Today: 23585
Total: 138543235
Forums › The Car › 206 Problems › Dashlights
Dashlights
Nosvartu
PostPosted: Thu Dec 08, 2011 2:43 pm Up
Okay i have been scouting around the site and I have had no luck to finding a solution to my little issue im having. I have a 04 plate 206 5 door. and all the lights on the left side of the dash are not working but all the ones on the right are working. there is a slight Glow to them. I have no idea how to get the console apart I don't dare break it. Can anyone shed some light on this situation?.
Mike
Newby
Ghosty
PostPosted: Thu Dec 08, 2011 6:18 pm Up
have you tried adjusting the brightness (push the little stick in on the left, it will cycle through brightness settings), if not that hen i know if its an multi-plex car which i think yours is, its an led board behind the clock face so you would have to replace the whole thing if thats gone. but someone else might have a better solution.
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
Nosvartu
PostPosted: Thu Dec 08, 2011 6:47 pm Up
I think i might have done this wrong i mean the center console the right side lights up left side has a faint glow to it but looks really dim. Its not the fuse as ive just replaced most of them.
Mike
Newby
Rob2859
PostPosted: Thu Dec 08, 2011 7:36 pm Up
You need a new bulb (509T) the display has 3 of them.
danlouiee
PostPosted: Thu Dec 08, 2011 7:54 pm Up
No there 286 size, you replace the bulbs and keep the holders! I made this mistake and order tons of 509t bulbs to be very disappointed! 286 or 284 size you will need and just swap them over:)
PostPosted: Fri Dec 09, 2011 4:56 am Up
Just buy the bulbs from any Peugeot / Citroen main dealer, there cheap enough.
Nosvartu
PostPosted: Fri Dec 09, 2011 5:49 am Up
Ahh okay :). Now for the stupid question how do i
Get the center console apart ??
Newby
PostPosted: Fri Dec 09, 2011 5:52 am Up
The forum search tool is a great feature.
www.206info.co.uk/Foru...t=mfd.html
Ghosty
PostPosted: Fri Dec 09, 2011 6:15 pm Up
i had this issue, i lifted the shroud up and out, then checked the connection to the MFD (center display) and it all came back on at full brightness try the simples solution first.
