Latest: Beduff1977
Overall: 17134
Online Now [1749]:
Visitors: 1748
Today: 271464
Total: 110435874
Forums › The Car › 206 Problems › Can cold weather drain a battery?
Go to page Previous  1, 2
PostPosted: Sun Dec 11, 2011 3:16 pm Up
D4NTP wrote:
The more often a battery is drained and needs charging from flat the quicker it will need replacing. i go through a fair few on the bike as i forget to trickle charge. hence why high end cars have trickle charging connections in the boot.
You usually trickle charge a battery when the vehicle it's on isn't being used regularly enough to charge it on a run.
D4NTP
PostPosted: Sun Dec 11, 2011 3:23 pm Up
Yeah, exactly. Bikes and high end stuff tend to be stood for long periods.
PostPosted: Mon Dec 12, 2011 10:31 am Up
devildriverxii wrote:
I ran a multimeter across it, it showed a 14v when the engine was off, and it went up to 15v when the engine was turned on.
Those values sounds slightly high.
Are you sure the alternator isnt overcharging the battery?
devildriverxii
PostPosted: Wed Dec 14, 2011 3:54 am Up
Hmm, this I can't be sure of. I'll check it again later to make sure.
Would an over charged batter cause it not to start then?
2002 1.6 5dr Black Edition.
PostPosted: Wed Dec 14, 2011 10:06 am Up
It wont do the battery any good in the long run Laughing
devildriverxii
PostPosted: Wed Dec 14, 2011 10:17 am Up
Man, I ask some stupid questions Sad
PUGPAUL
PostPosted: Tue Dec 20, 2011 10:55 am Up
yes
Peugeot 206 HDi (1.4cc) 'eco' - 2005
namgaj
PostPosted: Tue Dec 20, 2011 11:24 am Up
My batterys died after 3 years, mind you i'm told thats average for my car LOL
4.0 V8 S-Type Jaguar
Page 2 of 2
