Latest: tbafonso
Overall: 17130
Online Now [292]:
Visitors: 291
Today: 11952
Total: 104482079
Forums › The Car › 206 Problems › temp problem
temp problem
rug84
PostPosted: Tue Dec 13, 2011 11:32 am Up
Just wondering if anyone can help. Just bought a 1.6 glx that's had a new radiator fitted and the temp needle stays on the blue when the cars upto running temp. Everythings good apart from the heaters being cool all the time it wouldn't bother me so much but i have 2 young kids and with the cold weather here its no good can someone please help..cheers
206 1.6 glx but hoping for gti-6 power
davecuk
PostPosted: Tue Dec 13, 2011 11:47 am Up
hi. just wondering ,if you are at running temp,if there is a thermostat fitted or it's jammed open so the coolant won't get heated enough to get car heating,as you haven't had car long could be worth checking
206 1.9 d silver
HDI90
PostPosted: Tue Dec 13, 2011 12:10 pm Up
could also be a airlock in the system
GTI 180
PostPosted: Tue Dec 13, 2011 1:21 pm Up
check the thermostat,206 won't have airlock because the coolant bottle is higher than the water pump which mean all the air goes out in the bottle itself.
PostPosted: Tue Dec 13, 2011 2:49 pm Up
have you also checked the coolant level again since it been running? make sure its not low.
ramigojag
PostPosted: Tue Dec 13, 2011 3:15 pm Up
Sounds thermostat related to me
