Posted: Sun Dec 11, 2011 3:16 pm |
D4NTP wrote: |
The more often a battery is drained and needs charging from flat the quicker it will need replacing. i go through a fair few on the bike as i forget to trickle charge. hence why high end cars have trickle charging connections in the boot. |
You usually trickle charge a battery when the vehicle it's on isn't being used regularly enough to charge it on a run.
Posted: Sun Dec 11, 2011 3:23 pm |
Yeah, exactly. Bikes and high end stuff tend to be stood for long periods.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Mon Dec 12, 2011 10:31 am |
devildriverxii wrote: |
I ran a multimeter across it, it showed a 14v when the engine was off, and it went up to 15v when the engine was turned on. |
Those values sounds slightly high.
Are you sure the alternator isnt overcharging the battery?
Posted: Wed Dec 14, 2011 3:54 am |
MrBSI wrote: |
Are you sure the alternator isnt overcharging the battery? |
Hmm, this I can't be sure of. I'll check it again later to make sure.
Would an over charged batter cause it not to start then?
| 2002 1.6 5dr Black Edition. | |
Posted: Wed Dec 14, 2011 10:06 am |
Would an over charged batter cause it not to start then? |
It wont do the battery any good in the long run
Posted: Wed Dec 14, 2011 10:17 am |
MrBSI wrote: |
It wont do the battery any good in the long run  |
Man, I ask some stupid questions
Posted: Tue Dec 20, 2011 10:55 am |
yes
| Peugeot 206 HDi (1.4cc) 'eco' - 2005 | |
Posted: Tue Dec 20, 2011 11:24 am |
My batterys died after 3 years, mind you i'm told thats average for my car LOL
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
