Posted: Wed Dec 21, 2011 5:16 pm |
just thought, you said it was windy, could it have been one of the rear windows not shut properly, i have a friend whos 3 yr old takes great delight in leaving my windows off the catch (closed but not locked) could it be mb the wind was getting in that way and tripping the interior sensors.
Posted: Wed Dec 21, 2011 5:25 pm |
Maybe but knowing my luck it's more likely an expensive fault.
CHeers.
Posted: Thu Dec 22, 2011 4:37 am |
m4tth3w wrote: |
CHeers. |
Just buy some new ultrasonic sensors, there cheap enough from any Peugeot / Citroen main dealer.
Posted: Thu Dec 22, 2011 4:40 am |
Ghosty wrote: |
the only way to stop it going off from wind buffet would be to as said completly remove the alarm |
Its the ultrasonic sensors causing the problem, seeing as there cheap enough new from any Peugeot / Citroen main dealer its a simple diy job to fix the alarm.
Posted: Fri Dec 23, 2011 6:54 pm |
didnt realise the ultrasonics were part of the external protection, how does that work, as surely it would be a tilt/shock sensor.
i remember in my old nova i had an alarm fitted where i could set how hard it had to be hit before it triggered, weakest was a butterfly flapping its wings nearby would trigger it, strongest was pretty much kicking the pannels.
Posted: Fri Dec 23, 2011 6:55 pm |
learn something new everyday.....
Posted: Fri Dec 23, 2011 7:40 pm |
Ghosty wrote: |
No tilt or shock sensors on a factory 206 alarm, just faulty ultrasonics that dont like the windows being buffeted by the wind which in turn triggers the alarm.
