Latest: Kifi69
Overall: 17183
Online Now [459]:
Visitors: 458
Today: 73455
Total: 144365003
Forums › The Car › 206 Problems › 206 Gti 180 - Slow?
206 Gti 180 - Slow?
Cherry180
PostPosted: Sun Dec 25, 2011 9:39 am Up
So I took my partners Gti180 for a spin the other night and couldnt help but think 'it must have something up with it'
It feels flat as a turd, torqueless with no real fizz up the higher revs?
I myself have a Ph1 Clio 172, and it would utterly shame the 206 in a straight line (and the corners Wink )... Leading me to again think there's something wrong with the 206??
It doesnt have any running issues at all, no management lights etc... It just isnt packing as much of a punch as I would expect.
Do these suffer any blind problems? VVT Solenoid packed up or along those lines??
Cheers
2004 Peugeot 206 Gti 180\r\n2001 Ph1 Clio 172
HDI90
PostPosted: Sun Dec 25, 2011 9:59 am Up
If the vvt was playing up you would get beaten by a 1.0l micra. Has it had a good service at all?
If the timing belt has been replace by someone who dont know what they are doing that can throw the performance out the window too
cannot really think of anythink else other than maybe a blocked cat?
GTI 180
NICKST
PostPosted: Sun Dec 25, 2011 10:17 am Up
Happend to mine twice once when it was serviced with Ngk plugs instead and once when the vvt sensor broke.
PostPosted: Sun Dec 25, 2011 10:18 am Up
Awaits the " whats wrong with NGK plugs " question for the 50000000000th time on here Rolling On The Floor Laughing
HDI90
PostPosted: Sun Dec 25, 2011 10:20 am Up
I ran NGK for 50k in my xsi over 4 years and not once had a problem
GTI 180
PostPosted: Sun Dec 25, 2011 10:24 am Up
One of the lucky few then Wink
Plenty of people on here over the years have had lots of problems running NGK plugs in 206's Twisted Evil
starkie
PostPosted: Sun Dec 25, 2011 12:57 pm Up
ill be the one to ask... NGK problems?
Starkie =]
ramigojag
PostPosted: Sun Dec 25, 2011 1:03 pm Up
Im pretty sure the plugs in my 180 are NGK i dont have a problem with them, although they were the ones that came in the car so not really got anything to compare them to
HDI90
PostPosted: Sun Dec 25, 2011 1:38 pm Up
Old wifes tail that foats around here Wink
GTI 180
NICKST
PostPosted: Sun Dec 25, 2011 1:42 pm Up
No my 180 actually felt like 1.1 with Ngk swapped for bosch and was back to normal.
Cherry180
PostPosted: Sun Dec 25, 2011 1:46 pm Up
I think I'll give it a good service and go from there.
I would have imagined if the cambelt was done by some monkey, It be having more serious issues than slightly flat performance?
Perhaps run a diag over it also, see if it picks up any faults.
Is it worth taking the vvt solenoid out and cleaning it up (judging by searches on here) or is that just a place-bo thing on these?
HDI90
PostPosted: Sun Dec 25, 2011 1:49 pm Up
why did peugeot put them in then? ive know alot of ew10 engines running the no problem at all
GTI 180
Cherry180
PostPosted: Sun Dec 25, 2011 1:55 pm Up
Its quite funny as the Renault F7R is quite the opposite.
It came with NGK's and must only use NGK's, Bosch Super 4's are a big NO with them.
HDI90
PostPosted: Sun Dec 25, 2011 2:49 pm Up
Most PSA engines do too but some say they are the devil, ive never had a problem in any peugeot ive had running NGK,S in the past 12 years
GTI 180
NICKST
PostPosted: Sun Dec 25, 2011 4:03 pm Up
I do not now why they did because the Peugeot dealer I worked for didn't even stock ngk plugs just Bosch.
You wont no the differnce If you have all ways used Ngk unless you try the Bosch.
