Latest: Kifi69
Overall: 17183
Online Now [187]:
Visitors: 184
Bots: 2
Members: 1
Today: 10587
Total: 144157672
Forums › The Car › 206 Problems › Is this a battery problem?
chewitt
PostPosted: Sat Dec 24, 2011 3:06 pm Up
So Ive just recently bought my 206 Very Happy , and so far (until this morning) everything hasn't been too bad (apart from I only sometimes get an Aribag Fault message on the clock LCD Confused , anyone know what this could be?) anyway.... so yeah when it comes for me to get to work, i turn over the key and it doesn't start, i have a beeping noise at me and i have a "Immobilizer Fault" message come up on the clock LCD. t**t! Just my friken luck! Mad
As i was in work my neighbour had a look at the car and ended up having to start it with jump cables, and told me the battery had somehow died (even though id used it last night) he did a battery check on it and it said the battery was healthy?? So does this mean i have something draining the battery? I have also recently installed my Sony Head unit, could this be the little b*****d that's to blame?
Cheers
-Dave-
PostPosted: Sat Dec 24, 2011 3:25 pm Up
Trade Rating: +36
Not too sure about the fault but FYI you should never jump start a multiplexed 206 with jump leads. I'm sure that's fried a few in the past.
Ex 206 Owner.
chewitt
PostPosted: Sat Dec 24, 2011 3:32 pm Up
Whoa! Really? I best keep that in mind.
chewitt
PostPosted: Sat Dec 24, 2011 3:49 pm Up
Ive just found this,
www.206info.co.uk/Foru...art=0.html
It sound like the same problem im experiencing....
r1ch
PostPosted: Sat Dec 24, 2011 4:58 pm Up
should a multiplex car not be jump started because of the BSI? What will happen if it does get a jump start?
PostPosted: Sun Dec 25, 2011 8:27 am Up
You can crash the BSI software OR in worse cases kill the BSI unit.
Upset the BSI = your walking Laughing
starkie
PostPosted: Sun Dec 25, 2011 3:14 pm Up
what the hell are you supposed to do then? :S
Starkie =]
PostPosted: Sun Dec 25, 2011 4:57 pm Up
Take the battery off and charge it, or bump the car.
PostPosted: Mon Dec 26, 2011 7:11 am Up
Use your breakdown cover Rolling Eyes
chewitt
PostPosted: Fri Jan 06, 2012 9:54 am Up
Update: Turns out it was the battery that was at fault, well ive no problems so far after getting a new one!
Abzynthe
PostPosted: Fri Jan 06, 2012 11:39 am Up
East Area Rep - Abzynthe
Completely opposite to this, can you use a plexed to jump start another car?
-Dave-
PostPosted: Fri Jan 06, 2012 12:32 pm Up
Trade Rating: +36
Not sure if it's advised but I have used mine to jump start the in laws a few times now with no issues. I just wouldn't jump start my own.
Ex 206 Owner.
PostPosted: Fri Jan 06, 2012 5:15 pm Up
I have several times, no issues.
Just make sure you have a decent enough battery.
Matt
PostPosted: Fri Jan 06, 2012 6:46 pm Up
Trade Rating: +32
I used leads to jump start a friend Clio today. And my car was fine. Have also had my car done by the aa with a battery pack and that was fine also.
chewitt
PostPosted: Sun Jan 15, 2012 12:31 pm Up
Turns out the battery was dead! "Unserviceable" according to KwikFit! and so i bought a new battery for £49 from Unipart, i really wanted a Bosch or Varta but this will do just fine for now. I hope this will help others with similar problems!
