Forums › The Car › 206 Problems › Fan |
Posted: Fri Dec 30, 2011 10:51 am |
Hi guys not a problem as such but how would i go about making the rad fan work off a switch in side
Posted: Fri Dec 30, 2011 11:12 am |
ignition +12v > switch > fan > earth
Posted: Fri Dec 30, 2011 11:15 am |
Cheers so if i unplug it and take the conector off there will b only to wires 1 + and 1-
Posted: Fri Dec 30, 2011 11:21 am |
At the moment there will be a few wires around the fan as there are relays and a resistor for the fan speed, but you only need the two wires to make it work
Posted: Fri Dec 30, 2011 11:23 am |
ryanovsalford wrote: |
Hi guys not a problem as such but how would i go about making the rad fan work off a switch in side |
Why do you want to add a switch to make the fan work?
Whats wrong with the standard set up?
Posted: Fri Dec 30, 2011 12:48 pm |
Standard set up is perfect if it is working.
Posted: Fri Dec 30, 2011 2:13 pm |
Set up not working lol so got a spare switch might as well wire it up
Posted: Fri Dec 30, 2011 3:31 pm |
If it's not working then fix it. Chance are it's a crusty relay or broken wiring to the terminals of the relay. Some cars have two coolant sensors, could be one of those faulty.
Posted: Fri Dec 30, 2011 3:56 pm |
When i looks at the top of the engine there's two sensors a brown one and a green one could it b any of these because the temp guage has stopped working and there the only two that i can see go to the thermostat
Posted: Fri Dec 30, 2011 5:51 pm |
Yes sounds like you might have found the problem. Which one does what I do not know though.
Posted: Fri Dec 30, 2011 6:28 pm |
Now thats the big question might just go scrappy and grab on of each
