![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › Gti 140 brake issue |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Sat Dec 31, 2011 10:51 am |
I will have a look at the flexy's. might pop it to an mot centre and get the brakes checked there.
| | ![](images/spacer.gif) |
Posted: Sat Dec 31, 2011 12:35 pm |
Braided hoses do bugger all on a road car. If rubber hoses were that bad steel braided hoses would be fitted as standard.
Posted: Sat Dec 31, 2011 1:17 pm |
Edward wrote: |
Braided hoses do bugger all on a road car. |
I've got Goodridge braided hoses on mine, can't feel any difference over the standard flexi hoses.
Posted: Sat Dec 31, 2011 5:20 pm |
MrBSI wrote: |
Edward wrote: |
I've got Goodridge braided hoses on mine, can't feel any difference over the standard flexi hoses. |
same here
Posted: Sat Dec 31, 2011 7:30 pm |
Yeah must be true.
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport ![Cool Cool](images/smiles/icon_cool.gif) | |
| ![](themes/base/images/forums/otr.gif) |
