Latest: jackrox1992
Overall: 17186
Online Now [816]:
Visitors: 815
Today: 224642
Total: 147925982
Forums › The Car › 206 Problems › Help 206 not starting!!
griffsxi
PostPosted: Fri Dec 30, 2011 12:13 pm Up
Hi All,
Just tried to start my 206 and the engine barely turns over its like the battery is flat. I hooked up the mrs's car with jump leads but its still doing the same! It just wont start!
I've been looking on here abpout the earth strap from gearbox to the bodywork. Is there a way I can check by connecting a jump lead from the engine block to the bodywork myself to see if this is the probably?
All sugestions will be greatly received.
Many thanks
206 XSI
PostPosted: Fri Dec 30, 2011 12:16 pm Up
Tried bumping it?
Put a wire from -ve to chassis to rule out the earth
Test battery voltage or put your lasses battery on your car to rule out a dead cell
HDI90
PostPosted: Fri Dec 30, 2011 12:17 pm Up
Just watch what you are doing because i here you can mess the BSI up by jumping them. its not hard to check the earth strap just look under the barttery tray
GTI 180
griffsxi
PostPosted: Fri Dec 30, 2011 12:23 pm Up
Thanks I will go and have a look at the earth strap. Will the cable be obvious that it's f**ked? Is the any other erth cables I need to check?
Thanks for all your help
206 XSI
PostPosted: Fri Dec 30, 2011 1:12 pm Up
Not if it's just a loose connection. Earth goes to the gearbox and or chassis
Walton450
PostPosted: Fri Dec 30, 2011 5:02 pm Up
what ever you do, don't touch the throttle when you try and start it. because the idle control value will think that's its normal place when the car is running and you will find the car cutting out every minute.
I\'m Steve got a 2003 verve.
griffsxi
PostPosted: Mon Jan 02, 2012 6:09 am Up
Update - I checked the earth cables and they seemed in good condition. So went to Halfords today and got a new battery and that has sorted it! I probably should of did that first lol!!!
It just seemed odd that the battery just went like that, the day before it was fine Confused
Thanks everybody for all your help Smile
206 XSI
gixxerkev
PostPosted: Mon Jan 02, 2012 6:16 am Up
It only takes 1 cell to fail, even slightly, then the battery is buggered.
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Mon Jan 02, 2012 6:57 am Up
Modern batterys do just fail, its not like the old days where you got plenty of warning.
1 day they can be fine, the next its scrap.
