Latest: jtq4u
Overall: 17141
Online Now [80]:
Visitors: 79
Today: 35564
Total: 114004520
Forums › The Car › 206 Problems › Severe power loss...sounds like a tractor 1.4 8v
GLX_laney
PostPosted: Sun Jan 01, 2012 6:50 pm Up
Cheers man, will get it looked at in a proper garage tomorrow. That's if i get up the hill! Might just have to make use of 1st gear more than usual! lmao.
I.C.E killed my car.
tailhappy
PostPosted: Mon Jan 02, 2012 1:44 am Up
mine was the coil pack the 1 and 3 injectors and lambda sensor worth looking at all 4 of thoes as alot of people i know is EXACTLY identical probably
jamie bennett
DavidPCoates
PostPosted: Tue Jan 03, 2012 6:16 am Up
Sounds like injectors to me also, my recent problems were down to 2 injectors shorting out.
As previously advised, get it to a garage that has the peugeot code checker, they can eliminate certain things, and generally will have spare bits around to check on your engine, hence you dont have to buy parts.
Dave
Dave Coates
SmithyXSI
PostPosted: Tue Jan 03, 2012 7:48 am Up
I had a similar experience with a 1.1 TU engine, turned out to be coilpack. Does it smell of unburnt fuel at the exhaust?
2003 206 2.0HDi. I miss my 106 GTi.
GLX_laney
PostPosted: Tue Jan 03, 2012 12:04 pm Up
YES! I was wondering what this was...
Also, you have a PM Very Happy
SmithyXSI
PostPosted: Wed Jan 04, 2012 7:15 am Up
Well if it smells of unburnt fuel i'd be inclined to say at least one of your spark plugs isn't firing so its running on at most 3 cylinders. Which would explain the lack of power/rumbling etc. Either the spark plug is knackered or the coilpack is?
GLX_laney
PostPosted: Wed Jan 04, 2012 12:33 pm Up
Right lads.... Had it on a Diagnostic machine today. Garage basically came back to say it wasn't coil pack. (They were right) They told me it was the ECU that needed replacing. (Expensive job)
(Not being able to sleep until i knew i had tried another coil pack) I bought one from a car dismantler down the road (great reputation, so trust them dearly) i found that it definitely wasnt the coil pack.
In desperation and hoping, praying and begging it's not the ECU, i've bought a set of plugs to try tomorrow.
Fingers crossed. The end could be near! Crying or Very sad
danlouiee
PostPosted: Wed Jan 04, 2012 12:38 pm Up
How much they quoted on an ecu? Try and get a second hand one of possible?
GLX_laney
PostPosted: Wed Jan 04, 2012 12:43 pm Up
Embarassed They said a new ECU, i'd be looking at about a grand? Said they dont do it, but gave me a name of a garage in Ivybridge that would do fittings and repairs...
Hopefully, some new spark plugs will resolve all of my worries.
Hopefully.
206Mike
PostPosted: Wed Jan 04, 2012 1:50 pm Up
Ive had the exact same problem and was advised new ECU for similar price, Im guessing second hand from a 1.4 8V would do the trick. Is it just ECU, BSI, and key that are needed for an ECU swap?
+8 Pos feedback Smile
PostPosted: Wed Jan 04, 2012 1:52 pm Up
Ecu, bsi, key transponder chip & the transponder arial in the ignition barrel.
206Mike
PostPosted: Wed Jan 04, 2012 2:30 pm Up
Sweet as a nut, any guides on how to do it? Or is it a straight plug and play thing regarding ECU and BSI then a couple screws for the other stuff?
PostPosted: Wed Jan 04, 2012 2:40 pm Up
Get a haynes manual its prety straight forward.
GLX_laney
PostPosted: Wed Jan 04, 2012 4:09 pm Up
How much will a second hand ECU and bsi be? Sad
206Mike
PostPosted: Wed Jan 04, 2012 5:31 pm Up
www.ebay.co.uk/itm/Peu...780wt_1270
Page 2 of 3
