Posted: Sun Jan 01, 2012 6:50 pm |
Cheers man, will get it looked at in a proper garage tomorrow. That's if i get up the hill! Might just have to make use of 1st gear more than usual! lmao.
Posted: Mon Jan 02, 2012 1:44 am |
mine was the coil pack the 1 and 3 injectors and lambda sensor worth looking at all 4 of thoes as alot of people i know is EXACTLY identical probably
Posted: Tue Jan 03, 2012 6:16 am |
Sounds like injectors to me also, my recent problems were down to 2 injectors shorting out.
As previously advised, get it to a garage that has the peugeot code checker, they can eliminate certain things, and generally will have spare bits around to check on your engine, hence you dont have to buy parts.
Dave
Posted: Tue Jan 03, 2012 7:48 am |
I had a similar experience with a 1.1 TU engine, turned out to be coilpack. Does it smell of unburnt fuel at the exhaust?
| 2003 206 2.0HDi. I miss my 106 GTi. | |
Posted: Tue Jan 03, 2012 12:04 pm |
| SmithyXSI wrote: |
| I had a similar experience with a 1.1 TU engine, turned out to be coilpack. Does it smell of unburnt fuel at the exhaust? |
YES! I was wondering what this was...
Also, you have a PM
Posted: Wed Jan 04, 2012 7:15 am |
Well if it smells of unburnt fuel i'd be inclined to say at least one of your spark plugs isn't firing so its running on at most 3 cylinders. Which would explain the lack of power/rumbling etc. Either the spark plug is knackered or the coilpack is?
Posted: Wed Jan 04, 2012 12:33 pm |
Right lads.... Had it on a Diagnostic machine today. Garage basically came back to say it wasn't coil pack. (They were right) They told me it was the ECU that needed replacing. (Expensive job)
(Not being able to sleep until i knew i had tried another coil pack) I bought one from a car dismantler down the road (great reputation, so trust them dearly) i found that it definitely wasnt the coil pack.
In desperation and hoping, praying and begging it's not the ECU, i've bought a set of plugs to try tomorrow.
Fingers crossed. The end could be near!
Posted: Wed Jan 04, 2012 12:38 pm |
How much they quoted on an ecu? Try and get a second hand one of possible?
Posted: Wed Jan 04, 2012 12:43 pm |
They said a new ECU, i'd be looking at about a grand? Said they dont do it, but gave me a name of a garage in Ivybridge that would do fittings and repairs...
Hopefully, some new spark plugs will resolve all of my worries.
Hopefully.
Posted: Wed Jan 04, 2012 1:50 pm |
Ive had the exact same problem and was advised new ECU for similar price, Im guessing second hand from a 1.4 8V would do the trick. Is it just ECU, BSI, and key that are needed for an ECU swap?
Posted: Wed Jan 04, 2012 1:52 pm |
| Fowla wrote: |
| Ive had the exact same problem and was advised new ECU for similar price, Im guessing second hand from a 1.4 8V would do the trick. Is it just ECU, BSI, and key that are needed for an ECU swap? |
Ecu, bsi, key transponder chip & the transponder arial in the ignition barrel.
Posted: Wed Jan 04, 2012 2:30 pm |
Sweet as a nut, any guides on how to do it? Or is it a straight plug and play thing regarding ECU and BSI then a couple screws for the other stuff?
Posted: Wed Jan 04, 2012 2:40 pm |
| Fowla wrote: |
| Sweet as a nut, any guides on how to do it? Or is it a straight plug and play thing regarding ECU and BSI then a couple screws for the other stuff? |
Get a haynes manual its prety straight forward.
Posted: Wed Jan 04, 2012 4:09 pm |
How much will a second hand ECU and bsi be?
Posted: Wed Jan 04, 2012 5:31 pm |
