Latest: cogeim7
Overall: 17185
Online Now [548]:
Visitors: 547
Today: 220453
Total: 147118633
Project sleeper
Go to page Previous  1, 2, 3 ... 8, 9, 10 ... 85, 86, 87  Next
WilkyGTi
PostPosted: Tue Mar 09, 2010 5:19 pm Up
Whats the issue if you dont mind me asking? Just someone biting off more than they can chew? or general issues?
Eggs
Dillon
PostPosted: Wed Mar 10, 2010 2:41 pm Up
Staff - Dillon
never mind, only got to the end of the week with the Jetta
What He Said
PostPosted: Thu Mar 11, 2010 3:36 pm Up
I really like the Jetta. It's so comfy and refined...might need to invest in one someday...
Anyway a few pictures have arrived from Ecosse...It's not finished and from the pictures it's evident there is still all the wiring to do, cambelt needs fitting, the camshafts need timing, airbox needs fitting, throttle linkage needs fitting...mapping...a lot of still to go work. What's been done so far looks good though. I like the vernier pulleys. Should the cambelt covers be cut so the pulleys are on view all the time?
Jamie
PostPosted: Thu Mar 11, 2010 3:40 pm Up
How come your bodies are red? Is it because they're 42mm?
Keep the pulleys on show Cool
Are they doing the mapping in house or taking it somewhere else?
Do you have pictures of the VT engine mounts? I want to make sure they are the same design as the Baker ones before I buy them Very Happy
PostPosted: Thu Mar 11, 2010 3:47 pm Up
All bodies come in a choice of black or red don't they? I'm not sure where Ecosse do the mapping.
I've posted pictures of the VT engine mount on another post earlier in the week.
Jamie
PostPosted: Thu Mar 11, 2010 3:52 pm Up
The new search feature is less than good, so can't find it Sad
I feel conned, I was never given that option Sad
WeeDel
PostPosted: Thu Mar 11, 2010 6:48 pm Up
jesus wots with using vise grips on the shiney new cams??!!
"I TRUST EVERYONE! I JUST DONT TRUST THE DEVIL INSIDE THEM!!!"
SAB206
PostPosted: Thu Mar 11, 2010 6:50 pm Up
I cringed at the grips on cams too Sad
www.sab-graphics.com
I AM SYDLEXIC!
PostPosted: Fri Mar 12, 2010 2:34 am Up
They are only used on the shafts not the cam lobes so won't do any harm.
These cams don't appear to have anywhere for spanners to sit so maybe the grips are the only option.
gti180boy
PostPosted: Fri Mar 12, 2010 3:59 am Up
this is the same as the gti 180 cat cams.
on standed cams there a 24mm nut apart of camshaft so can turn camshaft on the cat ones there's nufin so cant turn it unless you molegrips or put bolt in end.
Smile
180 Doctor
no_offences
PostPosted: Fri Mar 12, 2010 5:25 am Up
addaz wrote:
Ruffy_206 wrote:
comes with 138 standard would think it would be over 160 mate
Well you say that....
But who says it still has 138? Or even left the factory with 138 to start with Wink
before my gti died it had 144, it was remapped to 146 in 2001 so engines can keep there bhp and its will p**s well over the 160 seriously
Signature removed due to size
Brian
PostPosted: Fri Mar 12, 2010 6:53 am Up
Trade Rating: +31
Wey hey Smile
That head looks stunning Cool
spike_202
PostPosted: Fri Mar 12, 2010 7:11 am Up
looking good ed, my pullys are on show,↲Did you not opt for a oil catch tank? As when you open it up it could get a bit messy in the air box if thats were there feeding the breather pipe to.
**spike's project**
TEAM:+200bhp
Brian
PostPosted: Fri Mar 12, 2010 8:03 am Up
Trade Rating: +31
It's safer to have the cam covers on i suppose. How would you cut the cover Paul?
PostPosted: Fri Mar 12, 2010 8:49 am Up
There are little circles already moulded into the cover. I'd just cut them out.
Page 9 of 87
