Latest: jackrox1992
Overall: 17186
Online Now [1071]:
Visitors: 1070
Today: 115335
Total: 148643892
Forums › The Car › 206 Problems › 1999 206 front roof mount antenna question
CH206
PostPosted: Mon Jan 02, 2012 8:46 am Up
Hi guys
Just sorting out my wifes 206 and found that the antenna was just glued in Sad guess that's why reception was crap.
Anyway, it does have a threaded end about 15mm long, yet the thread inside the head unit (on roof) looks to be much deeper in.
So I am wondering if this is the right antenna for the car?
Can anyone guide me on getting a replacement?
Mike
Mike, Sussex UK
PostPosted: Mon Jan 02, 2012 8:50 am Up
Go scrapyard. Find 206. Remove aerial. Job done. Wink
mrsc
PostPosted: Mon Jan 02, 2012 9:05 am Up
if you need a new aerial base a clio one fits it was of a w reg clio i had myn off
si
PostPosted: Mon Jan 02, 2012 9:12 am Up
They are cheap enough new from Peugeot/Citroen
CH206
PostPosted: Mon Jan 02, 2012 10:00 am Up
Thanks, can anyone confirm the length of the threaded pin on the end of the antenna? that way I can decide if I need the base or new antenna, thanks.
Mike, Sussex UK
PostPosted: Mon Jan 02, 2012 11:51 am Up
get a complete new one from Peugeot,it will be better
karimali831
PostPosted: Tue Jan 03, 2012 4:15 am Up
Mine snapped off, just get the aerial base so you don't have to re-wire:
www.ebay.co.uk/itm/PEU...247wt_1037
206 GTI 180
PostPosted: Tue Jan 03, 2012 5:58 am Up
£6.43 from dealer (656110) or £6.49 from egay.
While your at the dealer, might as well get the new washer nut for it too 693648 £0.41. At least then you know you have the right parts to make a good connection.
People seem to avoid going to the dealers because they think they are expensive. I've always found them fairly competitive on most items, plus you have the added bonus of knowing they are genuine and not some cheap import with a knocked up picture to advertise it.
CH206
PostPosted: Tue Jan 03, 2012 6:24 am Up
Hi and thanks, which bit snapped off please? I am trying to establish if the bolt on the base of the antenna is too short or if the threaded cup in the base is at fault?
Mike, Sussex UK
karimali831
PostPosted: Wed Jan 04, 2012 6:09 am Up
The base threaded off as I tried to tighten it back in place. Remove interior light and look if the bolt is secure, if it is and the aerial is wobbling then probably you have same problem I had. If you are too fiddly with it then it will snap so careful.
206 GTI 180
PostPosted: Wed Jan 04, 2012 2:08 pm Up
I agree with you on this,Original Parts all the way Very Happy
