Latest: S2cgm
Overall: 17178
Online Now [370]:
Visitors: 369
Today: 29646
Total: 137380881
Forums › The Car › 206 Problems › French piece of s***... help please!
Go to page 1, 2, 3  Next
PostPosted: Thu Jan 05, 2012 4:08 pm Up
Gonna keep this short and avoid a rant...
Just got in car and noticed the rev counter is stuck on 0.
Not sure whether it was fine when i pulled off then dropped as i was driving.
All other dials are working fine as far as i can see and car is driving and running fine.
Is this common? any suggestions?
Silvery206
PostPosted: Thu Jan 05, 2012 4:11 pm Up
The same thing happend to me but the actual speedo dial. Isit still dead or does it move a bit or isit inaccurate
Silvery 206
PostPosted: Thu Jan 05, 2012 4:12 pm Up
completely stuck on 0 will not move...
L5_UKS
PostPosted: Thu Jan 05, 2012 4:13 pm Up
Have you checked all the fuses? My old car did that and it was a fuse.
Mike_XS
Pull the cluster apart and check its on properly/not stuck?
PostPosted: Thu Jan 05, 2012 4:14 pm Up
fuses under the bonnet or under the steering wheel?
PostPosted: Thu Jan 05, 2012 4:15 pm Up
Your cars different, so its s**t im gathering
So i cant help, scrap yard?
adam, **** off
PostPosted: Thu Jan 05, 2012 4:16 pm Up
adam, **** off
To the scrap yard with your car?
Fo sure <3
PostPosted: Thu Jan 05, 2012 4:17 pm Up
Read the live data, if it's detecting the revs then the cluster is f****d
If not the sensor is knackered
PostPosted: Thu Jan 05, 2012 4:19 pm Up
I know it's not Peugeot but my mates berlingo did the same (1998). took batt off for 10mins and it was fine after that, just an idea.
PostPosted: Thu Jan 05, 2012 4:20 pm Up
Saxo has always done it, diagnoses equipment doesn't work with it so I checked all the fuses, replaced the cluster and it is still doing it.
Haven't got round to trying anything else yet
i'm simple when it comes to anything technical with cars as you well know... can you explain what you mean in idiot speak please Laughing
PostPosted: Thu Jan 05, 2012 4:22 pm Up
Plug the laptop in to see if it's reading the RPM Laughing
Scrap.
Yard.
Better?
Page 1 of 3
