Online Now [109]:
Visitors: 108
Today: 27836
Total: 105000777
Forums › The Car › 206 Problems › Very dim clock and stereo not working.
Fifer
PostPosted: Sun Jan 08, 2012 10:11 am Up
Went to test drive my 206 1.4 hdi 02 plate today and noticed the clock display was really dark. If you covered the screen and really looked you could see the numbers and it scrolled through correctly. Does this sound like a bulb problem. Also the stereo didn't turn on, don't know if it's linked but I'm not fussed about the stereo as I'm going to change it.
I was hoping for a mpg display but it looks like its the clock, temp display only.
1.4hdi 02
L5_UKS
PostPosted: Sun Jan 08, 2012 10:28 am Up
Either your brightness is set really low (hold the left hand knob on the dash beside the dials) or you need to replace the bulbs, replacing the bulbs is easy, think there's 3 or 4 little bulbs behind it.
Dabamash
Staff - Daba
Yeah, you need to change the bulb on the top. Fairly simple job, I'm sure there's a how-to on here in the how-to section.
Stereo is possibly not getting any electrical feed, but if you're changing it anyway, I wouldn't worry about it.
Dabamash
PostPosted: Sun Jan 08, 2012 10:29 am Up
Staff - Daba
206info.co.uk/Forums/v...t=342.html
woolah!
Fifer
PostPosted: Sun Jan 08, 2012 10:35 am Up
Cheers for the replies and the link to the how to. Definitely the bulbs or solder as I tried turning up the display and it didn't change.
1.4hdi 02
