Latest: Beduff1977
Overall: 17134
Online Now [591]:
Visitors: 590
Today: 156306
Total: 109151042
Forums › The Car › 206 Problems › TOP SUSPENSION MOUNT
gaznandrea
PostPosted: Mon Jan 09, 2012 7:41 am Up
i have a suspension top mount that has failed how serious is this and is it easy to repair
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
-Dave-
PostPosted: Mon Jan 09, 2012 7:42 am Up
Trade Rating: +36
Edit and write that again without the caps before you get Bum buggered by the forum police.
Ex 206 Owner.
need to take suspension strut out, compress spring then undo the mount and take off,
-Dave-
PostPosted: Mon Jan 09, 2012 7:45 am Up
Trade Rating: +36
And in response to your question I have watched mine come off while being lowered and it didn't seem that difficult. Once the strut is out its just a case of swapping over I believe.
Edit - After compressing the spring of course Laughing
Ex 206 Owner.
ramigojag
PostPosted: Mon Jan 09, 2012 8:59 am Up
its not massively difficult there are loads of guides on YouTube if your thinking about having ago yourself or if your going to take it to a garage it shouldn't be that expensive
PostPosted: Mon Jan 09, 2012 12:26 pm Up
Should be able to do it in less than 1 hour.
skard
PostPosted: Mon Jan 09, 2012 12:48 pm Up
what side has failed? i will be listing a brand new one with bearing this week as i literally just sold the 206.
i bought it from ECP a few months ago as a sided pair but only used the drivers side, so have the passenger one still.
