Latest: tebas93089
Overall: 17179
Online Now [57]:
Visitors: 55
Bots: 2
Today: 11752
Total: 138158834
Forums › The Car › 206 Problems › radiator fluid reservoir, can't see the level
m4tth3w
PostPosted: Mon Jan 09, 2012 2:06 pm Up
On my 01 206 gti the coolant reservoir is a milk white colour and I can't see the level of coolant through it.
It seems a silly design.
The only way I can check the level is to fill it to the top then siphon some out again.
How do you guys check your level? or is it just me that has a non transparent reservoir?
PostPosted: Mon Jan 09, 2012 2:24 pm Up
my eye sight is good enough to see the level
PostPosted: Mon Jan 09, 2012 2:31 pm Up
as your filling up keep sticking your finger in till you know it hits your finger.
or at dusk/night shine a torch into the tank and should see level.
PostPosted: Mon Jan 09, 2012 2:35 pm Up
Use a torch.
m4tth3w
PostPosted: Mon Jan 09, 2012 3:04 pm Up
Used a torch and still can't see it. Maybe my eyesight is crap.
I hope the low coolant light is reliable.
PostPosted: Mon Jan 09, 2012 3:16 pm Up
Look inside the bottle,and you will see a circle inside it smaller in diameter of the bottle,so when the coolant reach the top of it,it means it's on the max. level :),that what I do with my car,but not sure if it's the same with GTi cuz it's look diff.
m4tth3w
PostPosted: Mon Jan 09, 2012 3:46 pm Up
It's the flat bottle not the round one, and I can fill it till I see the liquid at the spout but that's 2 inches above the max line?
would have been nice if Peugeot used a transparent plastic like most other manufacturers.
IS it dangerous to fill up above the max line or should I just siphon a couple of inches back out every time?
PostPosted: Mon Jan 09, 2012 3:54 pm Up
Yeah you can get lack of pressure.
If you use anti-freeze, you should be able to see it anyway
PostPosted: Mon Jan 09, 2012 4:03 pm Up
Just take the cap off and squeeze the top radiator hose and if the level is correct you'll see the coolant.
PostPosted: Mon Jan 09, 2012 5:19 pm Up
Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing
It's on a French car, it's electrical related and you hope it's reliable.
I just look in the filler hole to check mine. Never had a problem that way.
