Latest: jackrox1992
Overall: 17186
Online Now [520]:
Visitors: 519
Today: 250555
Total: 147948480
Forums › The Car › 206 Talk › Cable or Rod gear change which is best
Forum Index › 206 Talk
206 gti Cable or Rod Gearlinkage 137 or 180
gti 180 cable type
0%
 0%  [ 0 ]
gti 137 rod type
100%
 100%  [ 3 ]
Total Votes : 3
briant
PostPosted: Wed Jan 11, 2012 7:32 pm Up
Maybe this has been covered before but im trying to decide which gear linkage to use im building a tarmac rally car & i have both 137 & 180 boxes and linkages so tying to decide which to use cable or rod i intend to use gears set from 180 as ratios are nicer for tarmac rallying, so i can fit it to either casing
im using 137bhp engine so afik i can use either
all feedback greatly appreciated
206 Rallycar
PostPosted: Wed Jan 11, 2012 8:21 pm Up
If you can stick to rods use them, these boxes are sloppy enough and the cables make them even worse.
HDI90
PostPosted: Thu Jan 12, 2012 3:31 am Up
last time i driven a 180 after giving it a bit of a hard time i missed the gears one or twice not sure if it was because it was cable but it felt strange
but the cable box did fell tighter
GTI 180
PostPosted: Thu Jan 12, 2012 7:14 am Up
Rods are more easily found at a scrappy if necessary. Therefore better supply of used parts.
macj
PostPosted: Thu Jan 12, 2012 8:36 am Up
Fit the constella quickshift kit (you will need to modify it) works great when correctly set up. Gives a nice tight snappy gear change when used with the 3 rod linkage kit.
Straighten out your gear lever and weld on the bottom collar when you have it in the correct place, keep the grub screw on the top one so you can pull it to bits later if needed
JE_180
PostPosted: Thu Jan 12, 2012 9:20 am Up
Don't use a 180 linkage lol, they're total dog s**t at the best of times, and cost a fortune to replace if they break...
Miles
PostPosted: Thu Jan 12, 2012 4:11 pm Up
Same Q/S is cheaper at Comp-brake, Looks like the same thing to me but cheaper
But never experienced the cable on the 206, but the 406 type is OK but will never be quick
If you need some rods, I'm sure I can sort you out a deal as you will be in compeition, PS. have you got the 180 Ratios?
The Pug Tuner and quality parts supplied
Engine & Box rebuild, Race, Rally, Track car's the only thing we don;t do is general servicing
briant
PostPosted: Thu Jan 12, 2012 5:57 pm Up
cheers for all the info i have a complete 180 box with the lower 1st gear and a 4.5:1 final drive with quaife ATB diff so it is really to decide which casing & selector rods to use
looks like ill use the rods
@macj i have the compbrake quickshift and was thinking id weld the bottom coller alright, can you recall what measurement you fitted the bottom coller up from bottom of lever
206 Rallycar
macj
PostPosted: Fri Jan 13, 2012 3:10 pm Up
I would fit it with the grub screws till your happy with the throw and then weld it up after..... I am not sure you will get the same result with my measurement
