Latest: jackrox1992
Overall: 17186
Online Now [1005]:
Visitors: 1004
Today: 29034
Total: 148199696
Forums › The Car › 206 Problems › 206 Gti knocking "With pic"
rick-gti
PostPosted: Fri Jan 13, 2012 4:00 am Up
my 2000 gti (138) makes abit of a knocking/ticking noise at around 2k rpm.
never heard it before as i had a staight through exhaust fitted, i now have the standard system on and it can be heard.
i dont think its coming from the head, could it be the exhaust manifold?
clio 197sport owner
rick-gti
PostPosted: Fri Jan 13, 2012 6:24 am Up
anyone got any ideas??
clio 197sport owner
shadow
PostPosted: Fri Jan 13, 2012 6:59 am Up
maybe exhaust heatshield loose/to close to bodywork
206cc 2.0 allure
PostPosted: Fri Jan 13, 2012 7:10 am Up
Its not the normal GTI manifold rattle / noise problem is it?
Official Peugeot warranty fix was remove exhaust manifold & spot weld the 4 inner tubes together & then spot weld them to the outer as well.
D4NTP
PostPosted: Fri Jan 13, 2012 7:56 am Up
Having a similar problem. As i have had the centre section and cat off i am assuming its either the manifold issue or the cat. Just need someone to lend me a foot to rev the car so i can trace the problem
rick-gti
PostPosted: Fri Jan 13, 2012 9:00 am Up
I will get someone to rev the car when Ive got it in the air and have a listen. Just hope its nothing internal.
clio 197sport owner
m4tth3w
PostPosted: Fri Jan 13, 2012 6:17 pm Up
I'm having the same issue on my 01 gti, although mine is through the rev range, louder when cold.
I had a oil and filter change today and it doesn't seem to make much difference. Anyway I just turned the radio up, because I'm not spending no money on the old knacker.
rick-gti
PostPosted: Sat Jan 21, 2012 4:44 pm Up
How hard is it to remove the exhaust manifold? I have sourced the noise to the manifold. I have heard that this is a common problem on the gti 138.
clio 197sport owner
PostPosted: Sun Jan 22, 2012 10:01 am Up
So common in fact that the Peugeot official warranty fix is to fire up the welder Laughing
rick-gti
PostPosted: Mon Jan 23, 2012 5:33 am Up
can this be done with the manifold on the car or does it need to be removed?
clio 197sport owner
PostPosted: Mon Jan 23, 2012 6:34 am Up
i have seen people doing this when the manifold is on the car
rick-gti
PostPosted: Mon Jan 23, 2012 8:15 am Up
is this where they rattle and need welding? (red dots)
clio 197sport owner
PostPosted: Mon Jan 23, 2012 10:24 am Up
Yes, also weld the 4 pipes together in the middle.
m4tth3w
PostPosted: Mon Jan 23, 2012 6:48 pm Up
This is probably a dumb question but if this was warranty would that mean it was a recall?
Would Peugeot still entertain a fix on a 11 year old car?
PostPosted: Tue Jan 24, 2012 3:38 am Up
No it was never a safety recall so it's not Peugeot's problem.
If the customer brought the car back for this issue under the Peugeot 3 year manufacturers warranty then the manifold would be removed & welded with no cost to the owner.
If the car was outside the 3 year warranty its new manifold time & the owner has to pay for it.
