Latest: jackrox1992
Overall: 17186
Online Now [1154]:
Visitors: 1153
Today: 77876
Total: 148842126
Forums › The Car › 206 Problems › 206 1.4 Hdi won't rev beyond 2800RPM UPDATE
pwbadi
PostPosted: Thu Jan 12, 2012 2:51 am Up
This issue started when it was very cold. Last week I changed the diesel filter but the problem is still on.
The engine management light had been on for the past 2 years but it did not cause any problems.
The mechanic says that we should clear the engine management light before we start looking at other things. I need to get this ASAP because I am planning to sell this car soon.
What are your suggestions?
206 1.4 Hdi
PostPosted: Thu Jan 12, 2012 3:02 am Up
It is in limp mode. Go have the codes read and that will tell you the problem.
Lecktorious
PostPosted: Thu Jan 12, 2012 3:42 am Up
Trade Rating: +59
This.
The fact you have left it for 2 years won't have helped.
'98 Nile Blue 306 GTi 6
-Dave-
PostPosted: Thu Jan 12, 2012 3:54 am Up
Trade Rating: +36
Engine management light on for two years. Are you Penny out of big bang theory Laughing
Ex 206 Owner.
PostPosted: Thu Jan 12, 2012 4:56 am Up
Haha I though that too Laughing
I'd fix it for her, full service too lol.
pwbadi
PostPosted: Fri Jan 13, 2012 1:56 pm Up
Must admit that I shouldn't have ignored the engine management light. But it was purely due to being mislead by the RAC man. The 206 being my wife's car hardly gets used. One day I decided to take it to work and didn't realise that the fuel was low. It stopped and the RAC guy got it started. However the engine management light came on. RAC guy said that it will clear after a fuel filter change. As it was a new filter I never changed it and only did around 800 miles since that incident ( Over 2 years)
After reading honest John forum, I have a reason to believe that my car needs either a top up of Eolys fluid or a DPF clean up.
But my car is a 2002 02 plate and I thought DPFs were introduced after 2004/05.
Do you think my 2002 1.4 hdi has a DPF?
206 1.4 Hdi
PostPosted: Fri Jan 13, 2012 1:59 pm Up
No it doesn't
Get the codes read, fuel filter wont cause a permanent fault
skard
PostPosted: Fri Jan 13, 2012 2:02 pm Up
mine was a late 2003 and didn't. i think the DPF is only in the 1.6 HDi range of a 206.
you need it scanned with peugeot diagnostics really.
pwbadi
PostPosted: Fri Jan 13, 2012 2:18 pm Up
What a relief!!. I really don't want to spend a lot of money as I am planning to sell and go for a 407. I know DPFs are known to give trouble.
206 1.4 Hdi
skard
PostPosted: Fri Jan 13, 2012 2:23 pm Up
there's probably someone on here with planet pug that could do a basic scan.
sorry to say it but your cars worth much less in its current state so you will be better off spending a few quid getting it right, and getting a better price for trade-in/sale.
pwbadi
PostPosted: Fri Jan 13, 2012 2:25 pm Up
Need to get it fixed before selling. Rest of the car is really good with a new clutch, timing belt and new front suspension.
I ve booked a scan on monday with a mechanic. Lets see what he says
206 1.4 Hdi
pwbadi
PostPosted: Tue Jan 17, 2012 1:37 am Up
Got it scanned last night . Code was related to the glow plugs, saying there is an error.
The guy who scanned was Polish and I couldn't understand some bits he tried to explain.
After we read the code, he opened the heater plug controller unit (set of relays in a fancy box) and identified a reverse current coming along the negative lead to a sensor. This prompted him to check the glow plugs and they were all faulty ( That is what he said)
And his final conclusion was that we cannot proceed with a diagnosis unless we get a full set of glow plugs, which makes sense.
However my concern was that I have never seen the glow plugs coming on for the past 2 years and the engine management light had been on for a very long time.
His answer to was that the glow plugs may not be the reason for the car to go on LIMP mode but the reason cannot be found unless we rectify what the code reader says.
The guy who introduced me has all confidence in this guy. So I am off to buy a set of new glow plugs
206 1.4 Hdi
jeoff82
PostPosted: Tue Jan 17, 2012 10:51 am Up
surely you can check the resistance values of the glow plugs with a simple multi meter to identify the dud plugs?
CFC
PostPosted: Tue Jan 17, 2012 11:50 am Up
Your getting rid of a 206 & going for a 407, you need your head looking at Wink
You would be far better of keeping the 206 unless you really need the space / load carrying capacity of a bigger car.
pwbadi
PostPosted: Tue Jan 17, 2012 12:26 pm Up
Need the space as I am getting rid of my Merc as well. One big car is enough. wife can take the bus
206 1.4 Hdi
