Online Now [329]:
Visitors: 329
Today: 70407
Total: 105964378
Forums › The Car › 206 Problems › knocking noise and service question
donkeyding
PostPosted: Mon Jan 16, 2012 12:06 pm Up
Evening,
when ever i set of slowly or set off just on the clutch i get a knocking noise. Had a nosey round and i presume it is going to be the gearbox/ engine mount.
Unfortunatly i really don't know any history of the car so I am going to be doing the cam belt and alternator belt and tensioners.
In the process whilst I remove the engine mount to do the cambelt I may aswell replace ALL the mounts.
Question is how many engine/ gearbox are there, and where is the best place to get them??
Also here is my service shopping list is there anything that I am missing or should buy?
*engine flush
*k&n panel filter
*pollen filter
*oil filter
*bosch super 4 spark plugs
*fuel filter
*oil been advised 10w40
*cam belt and tensioner
*alternator belt and tensioner
As I said I will also be replacing engine/gearbox mounts.
Anythign else or advise please let me know
cheers
dave
PostPosted: Mon Jan 16, 2012 12:15 pm Up
there's 3 mounts, if you want something decent easiest option is main dealer.
PostPosted: Mon Jan 16, 2012 12:46 pm Up
Shhhhhhhhh, dont mention main dealer for an engine mount, it might start you know who of again Wink
donkeyding
PostPosted: Mon Jan 16, 2012 12:53 pm Up
who is that then?? had a nosy online but seem to come across ones at £60+ a piece or £16 presume the latter is a standard item and the earlier is a uprated piece??
cheers
dave
donkeyding
PostPosted: Mon Jan 16, 2012 1:08 pm Up
another question,
i can find alternator belts but not a kit with tensioner. does it need a tensioner replacing or not???
cheers
dave
PostPosted: Mon Jan 16, 2012 1:11 pm Up
Alternator belt tensioner isn't a normal service item.
The list of the to do things is good,but you need to add water pumb to it,because it's a must to have it replaced when you change the cam belt.
donkeyding
PostPosted: Mon Jan 16, 2012 1:16 pm Up
yeh have that too, timon cheers
edward, I know it isn't pal but as i said i dont know the history of the car so need to do everything to make sure the car is 100%
also are these the 3 engine mounts i need??
www.eurocarparts.com/engine-mount
Cheers
Dave
PostPosted: Mon Jan 16, 2012 1:25 pm Up
Whos you know who?
