Latest: Worthy967
Overall: 17143
Online Now [586]:
Visitors: 585
Today: 2792
Total: 115647501
Forums › The Car › 206 Problems › dash lcd ribbon cable disconnected
Phr333k
PostPosted: Tue Jan 17, 2012 5:52 am Up
Hello,
I managed to get my dash LCD ribbon cable disconnected from the dash motherboard. It doesn't have any connector to reconnect it back. I tried sticking it back with a piece of tape, but the LCD won't work without me pressing it really hard. Is there an easy way to reconnect the ribbon cable ?
Tnx
Storm Grey 206 '00 1.4XR Presence
rick-gti
PostPosted: Tue Jan 17, 2012 6:07 am Up
If your talking about the lcd that shows the mileage I dont think it can be stuck back. Mine did this and I had to get another set of clocks.
clio 197sport owner
Phr333k
PostPosted: Tue Jan 17, 2012 8:14 am Up
yup, that's the mileage lcd
i'm searching for anything now, next step is buying new clocks :/
Lewis
PostPosted: Tue Jan 17, 2012 11:01 am Up
Can't you solder it?
Tivoli LX 1.1
Black GTI 180
White VXR Burg
Phr333k
PostPosted: Thu Jan 26, 2012 7:38 am Up
i can try...any tips or howtos before i do that ?
Rob2859
PostPosted: Thu Jan 26, 2012 9:15 am Up
I took a set of clocks out and both ribbons just fell out when I opened them up. They worked when I put them back in.
rick-gti
PostPosted: Thu Jan 26, 2012 9:51 am Up
i tried sticking mine but had no joy, dont solder it as its plastic so will melt.
the early 206 clocks to me are abit of a poor design, ive had two sets of clocks now one set the rev counter had packed up and the other the lcd ribbon had come off.
got a set now that work ok. i believe the multi-plex clocks are pretty good but wont fit the early 206s.
clio 197sport owner
mtempsch
PostPosted: Thu Jan 26, 2012 12:15 pm Up
As Rick says, heat will melt the plastic carrier film.
Maybe conductive glue, a very small dab on each conductor, tape to fix in place - probably one piece a bit 'up-stream' to fix it in place and secure placement before adding the glue to prevent smearing, then lift end slightly to apply glue and then add another piece of tape to hold the end down while curing.
Haven't tried it myself, but I believe it could work (as long as one has reasonable access to the spot)
Silvermetallic 2004 206 RC
Phr333k
PostPosted: Tue Jan 31, 2012 7:35 am Up
tnx guys, will try !
