Latest: lio94
Overall: 17181
Online Now [297]:
Visitors: 296
Today: 65219
Total: 142015712
Forums › The Car › 206 Problems › Car I'm selling.. engine just stopped
karimali831
PostPosted: Tue Jan 17, 2012 7:30 am Up
I'm selling my 1999 206 1.1 and engine is having some problems since it has been under ice frost the last few days, it wasn't running at all in days because I have a GTi car now.. wish I had run the motor every now and then!
At first engine failed to fire, second time it fired fine - very noisy.. Looked at engine bay and saw smoke rising for 20 secs and after 1 minute engine just cuts out altogether. When I raised the bonnet water drops started falling.. need to get this ready for sale in a day now.. with an engine working of course.. I am not sure if I should let it dry out then try start engine ? Sad
206 GTI 180
macj
PostPosted: Tue Jan 17, 2012 7:41 am Up
did it have antifreeze
karimali831
PostPosted: Tue Jan 17, 2012 7:54 am Up
I will check, I believe so though and now she's passed away... there is nothing at all, no battery/ignition/engine.
206 GTI 180
VorTechS
PostPosted: Tue Jan 17, 2012 8:05 am Up
Staff - Vortechs
If none of the electrical systems are firing, it sounds to me like it might be worth checking the main earth (usually located between body and engine/gearbox). It could be this has snapped (fairly common problem).
karimali831
PostPosted: Tue Jan 17, 2012 9:56 am Up
Thanks it was this!! Very Happy
Just went for the test drive is all fine except left indicate flashes twice as fast. Can this be fixed easily?
206 GTI 180
puggy206
PostPosted: Tue Jan 17, 2012 10:01 am Up
This could be because an indicator bulb has blown, try looking at all your indicators while there on and see which one has gone
Citroen DS3
D-style +
1.6 VTI
jimjam19927
PostPosted: Tue Jan 17, 2012 10:54 am Up
yer as above fast indicators generally mean there is a loose connection or something has blown. Its your car talking to you Wink
Member: 685
I Over Use Smilies Razz
TheGTIlad
PostPosted: Tue Jan 17, 2012 12:33 pm Up
What He Said
karimali831
PostPosted: Tue Jan 17, 2012 3:42 pm Up
that makes sense from the water spillage, thanks all. Smile
206 GTI 180
