Online Now [111]:
Visitors: 109
Members: 1
Today: 30748
Total: 138550310
Forums › The Car › 206 Problems › 2.0 HDi Performance issues?
chewitt
PostPosted: Wed Jan 18, 2012 3:05 pm Up
Right then guys this might seem normal to most owners of 2.0 HDi's but for me im not entirely satisfied in terms of performance, I'm sure some of you may shed some light on this but here goes...
So as I'm new to Diesels and Peugeots in general I've not really had a benchmark in terms of performance for me to relate to. My problem is that although my 206 is quite pokey, it seems to lose most its power just before hitting 70mph. Lets say I have a nice flat straight road, I pull off quite nicely rev only up to 3.5k through all the gears when it comes to 70, its almost as if i have no power, I mean it slowly increases speed but not greatly (no problem when im going down a hill). Is this normal for this engine? I ask this because I honestly though a 2.0 Hdi would be slightly better than this, i get that its quite not a GTi but I'm not convinced i have all my engine power?
Any ideas would be great!
Cheers
PostPosted: Wed Jan 18, 2012 3:09 pm Up
Mine will still pull at speeds alot higher than that.
What gear are you in at 70?
When did it last have a service?
PostPosted: Wed Jan 18, 2012 3:11 pm Up
So does mine and its even better with no cat
chewitt
PostPosted: Wed Jan 18, 2012 3:27 pm Up
I had a service done last week, they did mention that there was a performance issue when i removed the egr pipe, which i agree it didnt really do me much so i whacked th pipe back on. I had a noticeable peak in performance but im thinking because you guys still have pull beyond 70, i think something might be wrong! They also put it on a diagnostics tablet but this showed no issues with the car. Now just yesterday I had an Antipollution Fault show, this morning however I have no such fault! WTF!
PostPosted: Wed Jan 18, 2012 3:31 pm Up
Get the codes read again.
chewitt
PostPosted: Wed Jan 18, 2012 3:37 pm Up
I think i will go to my local and ask them to run a diagnostics on it. This is bugging the s**t out of me! I could just about overtake a frikken lorry with some ass riding my back en.. not good! Definitely think there's something wrong!
PostPosted: Wed Jan 18, 2012 3:42 pm Up
THis may sound stupid but what air filter you got on the car?
chewitt
PostPosted: Wed Jan 18, 2012 3:46 pm Up
Standard one dude, I've not changed anything under the bonnet. Well apart from a new battery.
PostPosted: Wed Jan 18, 2012 4:27 pm Up
Was it changed at the service?
chewitt
PostPosted: Wed Jan 18, 2012 4:33 pm Up
Im not entirely sure to be honest, but i know this problem has been going a little after i bought it. I figured it just may have needed a service and new cambelt kit but its still here!
PostPosted: Wed Jan 18, 2012 4:39 pm Up
Have a look at the filter and personally I would change it to a pannel filter from K'n'N.
Was it a full service as in major like having everything changed?
PostPosted: Wed Jan 18, 2012 4:40 pm Up
did it gone pass 70mph in 4th?
Frost
PostPosted: Wed Jan 18, 2012 6:24 pm Up
mine pulls quite nicely Smile start at the beginning check the filter, then check the intake piping, you are looking for blockages of kinks, have you checked your fuel filter? is there any crap in the sediment pot?, if you take the particulate filter off and put a straight pipe on insted you'll noice a increase in performance and responsiveness Smile (not sure what the new MOT rules are on this tho) a remap will up your performance and MPG too
"if someone has put it together then I will take it apart" it might never work again but at least I will have an understanding of how it worked and might be able to buy another
The voices in my head may not be real, but they have some good ideas!!
PostPosted: Wed Jan 18, 2012 6:28 pm Up
2.0HDi on 206 don't have particular filter
Frost
PostPosted: Thu Jan 19, 2012 5:10 am Up
so its a straight through pipe from the turbo to the mid box? learn summit new every day
