Online Now [554]:
Visitors: 553
Today: 84751
Total: 145390508
Forums › The Car › 206 Problems › fault codes
fault codes
loagmeister
PostPosted: Sun Jan 15, 2012 5:18 pm Up
hi everyone
im new to the forum
i kinda need advice, from more experienced pug drivers out there!!!!
ive got a problem with the g/f 206 cc 56plate
few weeks ago it showed up the abs light...... so plug my mates launch 431 into it, ... o/s/f abs sensor fault.
checked the live data on it........ all other sensors showing speed reading in line with the speedo head apart from the o/s/f showing 675mph Shocked Confused
so get a new sensor and fitted it, went to reset the light week later, fault code still there and light still illuminated Confused
so i tries my multimeter in the sensor through ac voltage but the multimeter let me down as to showing no voltage increase / decrease and even compared it to the n/s/f but no reading from my meter Confused
so 1 week later g/f tells me her speedo head isnt working and its now showing anti pollution fault, airbag fault, handbrake fault, so i plug in launch..... its now showing p0501 vehicle speed sensor a range/performance, p0040 remote intermittant vehicle speed, p0a50 supply voltage Confused
ive removed the new sensor/ and sent back under warranty in exchange for a new one which should be shortly Smile
i feel i should be able to deal with this Embarassed as ive been in the trade on the tools for over 10 year n more, my experience is jap and german, but little french, ive seen advice on this bsi reset to which im thinking of but will it really prove anything .
any and all advice welcome Smile
hey how ya doing
PostPosted: Sun Jan 15, 2012 5:30 pm Up
Have you got HIDs fitted?
Car is DC not AC current
Tested the wiring?
PostPosted: Mon Jan 16, 2012 11:13 am Up
Wonder if the ABS toothed ring on the driveshaft is cracked? Confused
loagmeister
PostPosted: Mon Jan 16, 2012 2:45 pm Up
hey lads
ive checked the abs ring, no cracks or teeth missing.
doesnt have HID
does a abs sensor not create its own current/signal ?
thus the voltage switching on and off. analog into digital
ive done this test with using a decent fluke meter on a hyundai getz in my old job
anymore suggestions welcome : )
hey how ya doing
PostPosted: Mon Jan 16, 2012 2:50 pm Up
Genuine ABS sensor from Peugeot / Citroen main dealer?
crocdino
PostPosted: Mon Jan 16, 2012 3:43 pm Up
What's the live data show after replacing the sensor?
GTI 138 facelift - Runabout
335d M Sport - Cruiser
loagmeister
PostPosted: Thu Jan 19, 2012 12:37 pm Up
hi mr bsi
i got the abs sensor from euro car parts............take it that might be a no no?
hey how ya doing
loagmeister
PostPosted: Thu Jan 19, 2012 1:17 pm Up
hi crocdino
regards to the live data, my mates launch was showing all other sensors working with the speedo head apart from the o/s/f to which that was showing the reading of 637mph!!! that i havent experienced before, but a week later the speedo head had chucked it! my mate suggested that his saab 93 abs sensor ran the speedo head on his car(what sensor on what side), he never really went into detail about it, but i kinda see he was maybe relating both together, but at to this present time that the engine management light came on now showing VSS fault code p0501& airbag light!!, i returned to his lockup to try launch again, i could access the engine management side to put out the light for the VSS but it came back on , but the launch was having no communication with the abs.
1. do spurious electrical parts for peugeot not really go hand in hand? my father works for them and
did say they dont really have complaints regards to using them.
2. my mates launch, he doesnt have the cables at hand to check the wave pattern direct with the abs sensor we fitted, and my voltmeter is crap.
3. i had a quick look around and under the gearbox for the speedo drive transducer but couldn't see it unless i've did it to quick, cause i drove the vehicle with my little code reader on live data and there was to reading from live data regards to vehicle speed.
4. i thinking it might be faulty new sensor as a guess so ive returned it for a new one in return so i should be fitting it this week weather permiting.
5. even when i fitted the new abs sensor, it was showing 0mph on live data while the other sensors showed readings in conjunction with the .... then at the time working speedo head.
all replys will be a big help to me.
hey how ya doing
PostPosted: Thu Jan 19, 2012 5:29 pm Up
Dont bother looking as it hasnt got one, speedo is linked to the ABS system.
Peugeot / Citroen part number 4545 F4 ABS sensor £45.82 including the VAT.
loagmeister
PostPosted: Sat Jan 21, 2012 10:12 am Up
thanks mr bsi
I'm fitting the new sensor today, if all fails,
I'll take a trip to peugeot for a sensor.
thank for the sensor part number
much apprecaited
hey how ya doing
PostPosted: Sat Jan 21, 2012 10:16 am Up
loagmeister wrote:
thanks mr bsi
much apprecaited
Double check that part number before ordering it Wink
It should be the correct one for your application.
loagmeister
PostPosted: Sun Jan 22, 2012 10:07 am Up
well shites hit the fan, ive a immobiliser fault. so car wont start : (
hey how ya doing
PostPosted: Sun Jan 22, 2012 10:10 am Up
Lock it with remote, unlock it with remote & try again.
If after a few trys it still wont play ball then reboot the BSI unit.
Sounds like a BSI software bug Wink
PostPosted: Sun Jan 22, 2012 10:31 am Up
Version 25 or 34 for immo software fault
PostPosted: Sun Jan 22, 2012 10:32 am Up
I know mine used to do it pre 2007 BSI update Laughing
Not had to get the 8mm spanner out the glovebox in years Cool
