Online Now [307]:
Visitors: 306
Today: 61774
Total: 105955771
Forums › The Car › 206 Problems › Airbag fault
Airbag fault
Go to page Previous  1, 2
karimali831
PostPosted: Sat Jan 21, 2012 8:58 am Up
MrBSI wrote:
karimali831 wrote:
MrBSI wrote:
karimali831 wrote:
The thick green/yellow, thick yellow and thin grey wires from driver A pillar has all been spliced and this airbag fault came up as soon after I was re-wiring them. Could this of caused airbag fault, surely no?
If this is the 180 then it will have curtain airbags & guess where the wires run Wink
Must of messed up again.. Evil or Very Mad
From installing headunit to anti pollution fault and installing rear light to airbag fault. Complex of multi-plex!
Nothing wrong with multiplex wiring.
Green & yellow is going to be an earth.
What are the wire numbers for the cables that have been spliced?
Sure you havent knocked a plug for the curtain airbag?
I am sure I only spliced the interior light wires from pillar and that is it, not sure why it interferes with airbag. I am just use to pre-plex, each wire for each something which makes things easier IMO.
206 GTI 180
karimali831
PostPosted: Sat Jan 21, 2012 6:32 pm Up
Got it now, there are two grey wires the same - I connected to wrong one which must of been airbag so airbag fault would trigger if I turn light on. Got light working and fixed airbag fault now by connecting to other grey wire. Very Happy
No idea how I didn't spot the two wires.. DOH!!!
206 GTI 180
PostPosted: Sun Jan 22, 2012 8:55 am Up
Your very lucky you didnt fire the srs system by tapping in to its wiring Wink
Page 2 of 2
