Online Now [303]:
Visitors: 302
Today: 35805
Total: 142304290
Forums › The Car › 206 Problems › GTi 180 Rear caliper problems
sri16v
PostPosted: Mon Jan 23, 2012 2:30 pm Up
Noticed the other day when pulling off that if felt like my rear offside brake was sticking slightly, fast forward to today when I can smell the brakes being hot after only completing a short, journey.
Could feel the heat coming off the brake assembly and noticed the outside pad has worn nearly all the way down, now I only changed these pads and discs on the rear in July so obviously something is amiss as the otherside has a lot more life.
Most likely to be a sticking handbrake mechanism? or the cable itself, or the caliper?
If its the caliper how much am I looking for a replacement, and do I require peugeot planet to bleed the new caliper?
2004 GTi 180
PostPosted: Mon Jan 23, 2012 3:38 pm Up
If you need new rear calipers. Pm me, I have a set that are less than 3k old that are sat here.
Mattie-RS
PostPosted: Mon Jan 23, 2012 3:43 pm Up
did you wind the piston back in?
sri16v
PostPosted: Tue Jan 24, 2012 11:58 am Up
Yep wound all the way back in with the correct tool, did this job back in the summer, Ive had a look tonight and the handbrake cable seems to be moving free enough, so Ive wound back the cable adjustment a touch.
Im guessing its going to be the caliper causing the problem, although the piston wound back nice and freely at the time i carried out the replacement
2004 GTi 180
