Latest: Kifi69
Overall: 17183
Online Now [551]:
Visitors: 550
Today: 33490
Total: 144325096
Forums › The Car › 206 Problems › What to do ....
What to do ....
SteveTDCi
PostPosted: Tue Jan 24, 2012 6:04 pm Up
I'm not 100% sure this will be the right section, but i'll give it a go Smile
My little 206 is in need of some love, now i'm not go to go crazy like some of you do so i'm going to keep it nice and simple and work through a few things, the idea is not to spend any money on it but i like things to be perfect so budget motoring goes out of the window Smile
Anyway, the car seems to be running a little rich, i've changed the thermostat and it now sits at a better temp and actually gets above 70 deg, i'm going to change the coolant sensor for what they cost as i believe it is a common issue and i think I might change the coolant. It has been done within the last 9 months when the headgasket was replaced but i guess its me being fussy.
There is a small leak on the exhaust as there is some black soot around the joint, this is where the pipework joins what i assume is the CAT pipework, its around the gearstick area. On the 206 are these metal to metal with some exhaust paste or is there a seal between the two ? If its a seal i'll get one first rather than taking it to bits and finding out later Smile
Next 02 sensors, are they prone to failing on the 206 ? this will be my next point for the running rich, the car ticks over fine, no missing or anything i'm going to change the plugs too. Is the 206 fussy about the oxy sensor or is any £30 one fine ?
Are there any other issues to look out for ? the car seems nice but just wants a little bit extra, oh and possible a door strap since it clicks Smile
The other question P2 lights, are they worth upgrading too on a P1 car (1.4LX) and are they easy to do ?
Cheers
Steve
206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out
PostPosted: Tue Jan 24, 2012 6:11 pm Up
Spark plugs = DON'T fit NGK to a 206!
Bosch plugs are a must.
O2 sensors rarely fail.
Phase 2 lights are simple plug & play, 1 x plastic wing nut is all that holds a rear lamp cluster in.
Change the coolant temp sensor & fix the exhaust leak & see if it runs better.
SteveTDCi
PostPosted: Tue Jan 24, 2012 6:20 pm Up
bugger .... I have NGK ones Smile with the lights ... its the front ones i'm thinking of, both the TT and Leon have xenons and these seem a little dim, and i'm not one for aftermarket conversions, i'd rather stick a brace of lights across the front WRC style Smile
Any idea if there is a gasket in the exhaust ?
Mike_XS
PostPosted: Tue Jan 24, 2012 6:21 pm Up
Phase 2 lights are definitely worth the upgrade!
SteveTDCi
PostPosted: Tue Jan 24, 2012 6:33 pm Up
Thanks Mike Smile
Mike_XS
PostPosted: Tue Jan 24, 2012 6:37 pm Up
I put HIDs on dipped and philips extreme on main. The light output is amazing. So much better than when I had the phase 1 lights in, they also look terrible lol.
PostPosted: Tue Jan 24, 2012 7:27 pm Up
Not reccomended with the HIDs though, you'll blind everyone. When did the car last have a service?
gixxerkev
PostPosted: Wed Jan 25, 2012 3:11 am Up
Changing the air filter may help with the "running rich" problem too, it did with my 1.4
An Ex '03 1.4 GLX driver, German technology all the way now.
SteveTDCi
PostPosted: Wed Jan 25, 2012 3:13 am Up
Car was serviced 7k ago, I'll look at the air filter, the oil doesn't seem too bad
Mike_XS
PostPosted: Wed Jan 25, 2012 3:31 am Up
Not if they are set up right.
SteveTDCi
PostPosted: Sun Jan 29, 2012 7:09 am Up
I need to get a Haynes manual but in the meantime where is the fuel filter on the 206 1.4 8v, I'm assuming it's at the back near the fuel tank. I've searched but not found it - the forum that is. I was going to change the plugs but since I have NGK ones I'm going to listen to forum advice and get the Bosch ones, if someone doesn't mind Ngk's then you can have them £5 posted
macj
PostPosted: Sun Jan 29, 2012 7:34 am Up
try these
SteveTDCi
PostPosted: Sun Jan 29, 2012 12:27 pm Up
Ha ha, I did google them but ones with 4 xenons and made from carbon fibre were double what I paid for the car Smile
PostPosted: Sun Jan 29, 2012 5:06 pm Up
Yeah but its virtually impossible to sort out the washers, auto levels, and the fact that the light internals are all wrong.
PostPosted: Sun Jan 29, 2012 5:09 pm Up
HIDs are fine as long as they are aligned and you don't buy China crap....you won't blind anyone.
